Refrigerators Logo
Question about Electrolux Refrigerators
Electrolux wine cooler R134a door sensor
The fridge door is beeping and the light goes on after it's closed. It stops and the inside light turns off when I put pressure the lower left corner of the door, with my foot. Where's the sensor?
Posted by Peggy Concepcion on
Paul Bade
  • Electrolux Master
  • 1,777 Answers
I don't see any door switch or sensor in the electrical diagram; maybe it's mounted on one of the circuit boards and is operated by a mechanical actuator. On most refrigerators, that's near the top of the door.
From what you describe, maybe you should check for a warped door or a loose, bent or worn door hinge.
Posted on Mar 13, 2023
My fridge keeps beeping even with the door closed beeps for a while stops beeps again why and how can I stop this
there is a switch somewhere in the door frame, typically a little triangle which you can push in by hand and then the light should go out. If it does not, then the switch is bad.
If you can't find the switch, put your kid inside the fridge and close door to see if the light goes out, hehe
Why is my whynter wine cooler beeping and flashing the display
due to many reasons, your whynter wine cooler temprature can beep
the main reason is to disrupt the proper storage
not at the adjustable place
also read for further detail...
https://kitchencol.com/whynter-wine-cooler-temperature-flashing/
Aug 31, 2014 • Furniture
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Zanussi zenb9950si
What is the beep for ? Temperature sensor ? Power sensor ? Door open sensor ?
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
Why is there water in the bottom of my wine cooler
cos you have condensation inside due to the fact that it is not frost free OR you have a seal leak.....OR the door is constantly open and closed (my beer fridge is like that.....)
1helpful
2answers
My light for my marvel wine fridge will not turn off?
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Top Electrolux Refrigerators Experts
Marvin
Marvin
David Shaub
Thomas Rutkowski
Thomas Rutkowski
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
