One of my dual electric burner inner element is not heating up but the outer works fine, is the burner or circuit board
Could be either, but test the continuity of the heating elements with a multimeter first.
Testimonial: "not sure which terminals to use to check for continuity, wanted to post the picture but do not see the attachment option"
Check them all ways. They will be the ones on the white block. They the top two then the bottom two, then try top left and bottom left, then top right and bottom. The bottom left looks like it might be a common return, in which case it is the negative on that and probe the other three. The sequence there would be inner element, outer element and both elements. The slightly out of focus tag lower down would be grounded earth to the element casing.
You could also Google 'make model wiring diagram'.
Picture 137 and 209 are the only one with continuity, wondering if picture 148 is the connection for the small burner
Yes, it looks like the fault is with the inner element. Replace the burner unit.
