IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
