Cell Phones Logo
Question about Nokia Cell Phones
My Nokia 2760 won't let me send messages to anyone, how do I fix it?
I have had the phone for two months now, and this problem just started
zulfiqar ali
    Novelist:
  • 83 Answers
If your Nokia 2760 is not allowing you to send messages to anyone, here are some steps you can try to fix the issue:
  1. Check your Network Connection: Make sure that your phone is connected to a network and has a strong signal. Weak network signals can cause messages to fail to send.
  2. Check Your Message Settings: Make sure that your message settings are correct. Go to the messaging app, select options, and then select message settings. Check the message center number and the message type to make sure they are set up correctly.
  3. Clear the Cache: Clear the messaging app cache to remove any temporary files that may be causing issues. Go to the messaging app, select options, and then select clear cache.
  4. Restart Your Phone: Restarting your phone can often help to resolve any issues. Turn your phone off and then on again to see if this fixes the problem.
  5. Reset Your Phone: If none of the above steps work, you may need to reset your phone to its factory settings. Make sure to back up any important data before doing so. To reset your phone, go to settings, select phone, and then select restore factory settings.
If none of the above steps work, it may be best to contact Nokia support for further assistance.
Posted on Mar 09, 2023
1helpful
Need a restriction code for Nokia 2760
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
2answers
Unlock code for nokia 2760
Hi, You can get the unlock code for a Nokia 2760 from www.prounlocking.com/nokia-2760/rs8wp9/ at affordable cost. Here are the steps for unlocking a Nokia 2760,
1 - Switch on your Nokia 2760 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2760.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2760 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2760 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
My nokia 2760 will not finish opening a message, is stuck in standby and I can't even turn it off
Remove and replace the battery (leaving the battery out for at least 30 seconds). If that doesn't fix it, the phone is probably ready for retirement :(
1helpful
I want to airtel gprs setting so what message send to mobile 2760
write the massage as "MO"and sent it to 54321 from your airtel number. u will get Gprs setting .
When sending TEXT Messages it gives error multimediat message settings not defined
you must select the option new text message to write and send text message...here u have selected the multimedia message sending option...for sending multimedia messages,u must have the settings from the service provider..u can obtain it from the service provider by contacting their customer care..
Nokia 2760
for it u need to configeration from ur service provider. when u need it then plz contract with service provider
1helpful
2answers
I cant use my nokia 2760 because it's asking me for a security code. My phone has been lost for months and I just found it. Now I cant even use it because of this dumb security code..... How do I unlock...
you will need to try online or you can take the phone to a mobile service center and hvae it done or give us your IMEI# you can do this by pressing *#06#
7helpful
2answers
Restriction Codes
my new phone nokia 2760 is demading the restriction code
Jan 05, 2009 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Marvin
Marvin
matt
matt
