A blurred screen on the right-hand side of a Blaupunkt TV for about 2 inches from top to bottom can be caused by a few different issues, such as:
A problem with the display panel: The display panel may have become damaged or malfunctioned, causing the blur on the right-hand side of the screen.
A problem with the T-CON board: The T-CON board controls the video signal between the main board and the display panel. If it is not working properly, it can cause the blur on the right-hand side of the screen.
A problem with the main board: The main board controls the various functions of the TV. If it is not working properly, it can cause the blur on the right-hand side of the screen.
A problem with the cable or connector: Damaged or loose cable or connector can cause the blur on the right-hand side of the screen.
It's best to consult the manual or a professional technician for help. They will be able to diagnose the problem and recommend the appropriate course of action. Sometimes, the problem can be solved by replacing a faulty module, repairing or replacing damaged cable or connector, but in some cases the repair may be more complex and require more extensive work.
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
My KDL-52W4100 just started doing the same thing. It blurs down the right side of the screen, then goes back to normal after it warms up. Does anyone know whats up with this?
Convergence amp ic bad http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html http://www.hdtvoice.com/voice/showthread.php?t=28929 Or send to ptscorp.com http://www.hdtvoice.com/voice/index.php?s= good luck
please mark the post with a fixya
You may have a defective dynamic focus circuit or or the Hi Voltage transformer. if your not a tech it is advised that you call in a trained tech as this is not a place for an experimenter to be. TO MUCH HI VOLTAGE and will make you cry if you live!!!!Good Luck
