I posted a question yesterday but it vanished. Does anyone know why?
What was the question we wonder.
Testimonial: "I don't think any of these "experts" are actually reading my comments. I won't use this site again"
1 Move slider to HOT WATER or HEATING, then press + or - to adjust the “On” time for Period 1 as shown at left. 2 Press OK to save, then press + or - to adjust the “Off” time for Period 1. Repeat for all time periods.
3 After all Monday time periods are set, press the NEXT DAY button to adjust settings for Tuesday.
Etc etc.
Resetting a Honeywell Thermostat
Power off the thermostat and remove the batteries.
Put the batteries in the wrong way, with negative to positive and positive to negative.
Wait ten seconds and put them back in the correct way.
Your thermostat will be reset to factory settings.
Press the Menu button. Press the "+" button until "TIME" appears. ...
You will see "12HR" appear. Here you will be able to choose 12 or 24 hour clock options. ...
This will then bring you to the option to edit the time. ...
Press + or - to adjust the minutes.
Hope this helps.
The crystal oscillator can drift in time after many years of use. A repair is not practical unless access to specific test gear is available. Most workshops haven't got the expertise.
I would replace it with an up to date wireless system, Honeywell supply a number of these. Here is a list in the UK from just one trusted supplier; https://www.screwfix.com/c/heating-plumb...
Straight forward to install by most people with an engineering background.
I know how to do all this, but setting the timer does not work. When i slide the switch to timer, nothing happens. I can set the water and heating ok but the clock is 5 min slow and gradually getting slower
I think these posts are by robots who are picking key words without reading my comments. This is the only wxplanation I have as to why they cannot understand my questions. I will not use this site again
