Question about Epson Office Equipment & Supplies
How do I access the waste ink tank/pads for an Epson Stylus DX8450 printer
Posted by Susan Erdmann on
Javed ali
    Scholar:
  • 44 Answers
The waste ink tank/pads for an Epson Stylus DX8450 printer are located at the bottom of the printer's housing, beneath the print head. Here are the steps to access and replace the waste ink tank/pads:
  1. Turn off the printer and unplug it from the power source.
  2. Open the printer cover to access the ink cartridges.
  3. Gently push the print head to the right to move it to the ink cartridge replacement position.
  4. Look for the waste ink tank/pads at the bottom of the printer housing, just beneath the print head. They may be covered by a small plastic panel.
  5. Remove the plastic panel, if present, by gently pulling it toward you.
  6. Use tweezers or gloves to carefully remove the old waste ink tank/pads from the printer.
  7. Replace the old waste ink tank/pads with a new one, making sure they are seated properly.
  8. Replace the plastic panel, if present.
  9. Push the print head back to its original position.
  10. Close the printer cover.
  11. Plug the printer back into the power source and turn it on.
  12. Reset the waste ink counter by following the instructions in your printer manual or by using a reset utility program.
It's important to note that replacing the waste ink tank/pads can be a messy and complicated process, and it may be best to have it done by a qualified technician or Epson service center to avoid damaging your printer or causing a mess.
Posted on Mar 03, 2023
Testimonial: "Many thanks for your very prompt and comprehensive reply to my question."
1helpful
Replacing waste ink pads on epson rx685
Actually it will very hard for you to access the ink pads for it was designed to be only touched by their service center. I would pressume your printer is giving you errors on waste ink pads full? Try this to reset the counter and be able to use your printer again..
http://fix-your-printer.blogspot.com/2010/04/how-to-reset-epson-stylus-photo-rx690.html
2helpful
Epson stylus c67
Your printer needs to be reset, you need a software resetter,you can use SSC utility. But you must clean first the waste pad inside the printer or the best thing there is to move the waste hose outside the printer.There is a waste hose that is going through the waste pad then instead of letting it throwing ink on the waste pad, change the direction of the hose,point it outside the printer and put external vessel or tank where to dump ink.
2answers
Printer has ink BUT has stopped printing
It is your print head, not ink cartridge
It is reasonably easy to change yourself - google for Stylus C70 printer head
2helpful
2answers
Parts inside your printer are coming to the end of their life
It could be the Waste Ink Pad. Call Epson tech support for the correct answer. If it is the pad go to the site below and get a Waste Ink Container. It sits outside the computer. Lood at the CISS, it will save you Tons of money.
http://www.inkproducts.com/ink-store/
2answers
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
2helpful
2answers
Epson stylus c45
most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
3helpful
2answers
2helpful
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
11helpful
3answers
Reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Top Epson Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
