Video Game Consoles & Games Logo
D
Dorothy Posted on Feb 24, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disc format thats wat it says wen i try to go to videos
Cant go back on videos
Anthony
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Expert 419 Answers
  • Posted on Feb 24, 2023
Anthony
Expert
Level 2:
Legend:
Answers
419
Questions
Helped
64447
Points
928
What device are you trying to access the videos on? Is there any error message or code displayed on the screen when you encounter this issue?
My wii is send trouble shoot shut off wii and check owners manual for problem fix wen channel screen comes on I can see hand moves around then send me that wats wrong my kids knocked off stand
Try cleaning it out first. Make sure there is not a disc logged in there sometimes when they fall it can cause the cd to become off track. Make sure if it is you might have to open it up and take it out some how.
11answers
DCR DVD 405
THIS is great wat to learn about what is the PROBLEM
When i put my psp inti my loptop..i upload a music wen i see the upload files no one..why...and why my psp cant read a umd
Please make sure the file extension is MP4 format. Your psp working in this kind of format.
For your UMD also need to check your disc for correct format. If it is correct, you may have defective lens and need a replacement
Wat do i do wen my game gta 4 is installing ver 1.04 and it keeps failing
It sounds like a typical loading error or an overheating problem, which would point to 3 main issues.
1. your disc is either dirty or scratched.
2. Your laser is out of alignment and needs to be tuned or replaced.
3. Your PS3 unit is overheating and causing the unit to freeze
Typically it is the disc that is at fault.
Try to troubleshoot by doing the following.
1. Try another disc. Preferably a new disc as then you can be absolutely sure that the disc is not scratched.
2. Try unplugging all the cables and then plug them back in again making sure they are all firm
3. Try putting a fan on your unit - keep it off carpet and in a well ventilated area. Fans work best.
If the first 3 options did not solve the issue you may need to send your unit in to get the laser aligned or replaced or the units internal fan checked.
Hope this has helped
3helpful
My yp-k5 is not working.........the screen buttons itself is disabled..wen switched on.....i get a message.to delete 20 mb files......how can i do that wen d buttons itself r not working.....i tried...
First off, make sure the unit is not on hold. You can check that by looking at the side for the HOLD switch.
Next try to reset the player. Here's how you do it:
With the unit, get a paperclip and poke the reset hole at the back of the unit until the unit shuts off.
Try to turn on the unit and check if the buttons will be activated. If they'll work, format the player.
Next, what exactly happens when you try formatting the player using your PC?
You can try going to My Computer. There, you're going to see teh YP-K5. You DO NOT format that. Rather, double click on it. You're suppsoed to see a STORAGE folder. Right click on that directory and select FORMAT.
Hope this helps!
xo
R
Wii:disc stuck and wont turn on
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Formatting probem
your os cd gone bad, try to get another os cd and boot the system from that cd.
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
