Expert
- Posted on Feb 24, 2023
Re: The anti flood device has activated on my AEG...
If the anti-flood device has activated on your AEG dishwasher, it means that water has leaked into the base of the dishwasher and triggered the safety device. The anti-flood device is designed to prevent water damage to your home and shut off the water supply to the dishwasher.
To resolve this issue, you will need to locate the source of the leak and fix it. Here are the steps you can take:
- Turn off the dishwasher and unplug it from the power outlet.
- Disconnect the dishwasher from the water supply and move it away from the wall.
- Check the inlet hose, outlet hose, and drainage hose for any cracks, damage, or loose connections. Tighten any loose connections and replace any damaged hoses.
- Check the dishwasher door and gasket for any damage or debris that may prevent it from closing properly.
- Check the dishwasher's interior for any leaks, such as a cracked spray arm or a damaged pump.
- Once you have fixed the leak, you can reset the anti-flood device by tilting the dishwasher to one side to allow the water to drain out of the base. Then, level the dishwasher and plug it back in.
If you are unable to identify or fix the leak, it is recommended to call a professional technician for assistance.
