Expert
- Posted on Feb 24, 2023
Re: My LG top load washing machines WF -T8019TC show an...
The E2 error code on an LG washing machine usually indicates a problem with the water supply. Here are some steps you can try to resolve the issue:
- Check the water supply: Make sure that the water supply to the washing machine is turned on and the water pressure is adequate. If there is a problem with the water supply, fix it and try running the machine again.
- Check the water inlet valve: The water inlet valve is responsible for controlling the water flow into the washing machine. If the valve is faulty, it can cause the E2 error code. To check the valve, unplug the machine and turn off the water supply. Remove the hoses from the valve and check if there is any debris or damage. If the valve is damaged, it will need to be replaced.
- Check the water level sensor: The water level sensor is responsible for detecting the water level in the washing machine. If it is faulty, it can cause the E2 error code. To check the sensor, unplug the machine and locate the water level sensor. Check for any damage or debris and clean it. If the sensor is damaged, it will need to be replaced.
If the above steps do not resolve the issue, you may need to contact a professional for further assistance.
