A
Anonymous Posted on Feb 19, 2023
Blackweb BWD19AAA06 speaker wire color diagram please?
ADMIN Andrew
Level 3:
Top Expert:
  • Audio Player... Master 66,963 Answers
  • Posted on Feb 20, 2023
ADMIN Andrew
Level 3:
Top Expert:
Answers
66963
Questions
Helped
5085993
Points
379812
Blackweb is Walmart's bargain basement brand. The only place you would get that information is from the maker in China. Run a request through Google Translate.
Generic help and the manual in the link.
https://www.google.com/search?q=Blackweb+bwd19aaa06+speaker+wire+color+diagram
I need the radio wiring color diagram for my delco radio, 1998 corvette
1998 Chevrolet Corvette Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakers
Front Speakers Location: Kick Panels
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6?
Rear Speakers Location: Rear Sides
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
2helpful
2answers
I bought a DVD player for my 2006 Mitsubishi Lancer. Thr new unit came with wiring diagram, however there is no information on the original Mitsubishi harness to match wires. The unit has a Fujitsy sticker...
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Best Buy installed a new cd player in my 03 Tiburon GT. All of my instrument cluster lights no longer work. The fuse is ok. Anyone know the wiring color codes. Best Buy is unco-operative and want me to...
Is fuse 29 the one you say is good? If that fuse is good, check your tail lights. If the tail lights are not working either, check the TAIL LAMP fuse in the engine compartment relay box.
There are 2 different wiring diagrams depending on if you have the amplifier or not. If you have only the basic radio, it would not have the amp. If you have a premium option, it would have the amp.
There is also another wiring color code I got from another website that's different--more like the standard colors. I'm going to include that color code as well in case you find the colors don't match the diagrams.
In the diagrams, there are actually 2 wires that run the light on the radio. One is green and one is brown with a white stripe. An aftermarket CD player will probably not have any wires for the light and just have it come on when the radio is on--day or night. So, if they connected those factory wires anywhere, that may be your problem.
I have pasted all of the relevant wiring diagrams below, though they may be hard to read because of picture size policies at FixYa. Please let me know if you have more questions.
Possible alternate color scheme:
Radio Constant Wire 12V+: Red
Radio Ignition Switched Wire 12V+: Yellow
Radio Illumination Wire: Pink/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Factory Amplifier Turn On Wire: n/a
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Black
Right Front Speaker Wire (-): Yellow
Left Rear Speaker Wire (+): Blue
Left Rear Speaker Wire (-): Red
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Orange
4helpful
2answers
2002 Taurus stereo
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
4helpful
2answers
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
12helpful
3answers
Stereo wiring diagram
2006 Ford F150 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Light Green/Yellow
Car Radio Illumination Wire: Light Blue/Red
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
 Grubhead
Grubhead
SmartAviator
SmartAviator
