Question about HP Office Equipment & Supplies
How to remove error #c3-1312 in hp laser jet printer m438nda
Posted by PRAMENDRA HADA on
Pawel Nietyksza
    Master:
  • 318 Answers
  1. Turn off the printer and unplug it from the power source.
  2. Wait for a few minutes, then plug the printer back in and turn it on.
  3. Check if the error has been cleared.
If the error persists, you may need to perform a firmware update. You can do this by downloading the latest firmware from the HP website and following the instructions provided to install it on your printer.
If you continue to have issues with error #c3-1312, it is recommended to contact HP Support for further assistance
Posted on Feb 08, 2023
How can solve 59.3 error hp laser jet pro 402
hp laser jet pro 402 printer 50.2 or 59.3 error has first check your power WATS then fussier & heat element
How do I disable HP ToolboxFX error alerts
how about installing a new laser jet HP printer tool box fx...
1helpful
Scaner error 52 in my laser jet printer printer model :-hp laser jet 3052 all in one printer
52 Scanner Error
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the FFC connection between the formatter and the scanner.
NOTE Do not bend or fold the FFCs during the removal or reinstallation process.
4. Try connecting the product to a different power source or surge protector.
5. Turn on the power and wait for the all-in one to initialize.
6. If the error persists, replace the laser scanner assembly.
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
3helpful
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
32helpful
2answers
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Clive
Clive
Ben Johnson
