Question about Sony Office Equipment & Supplies
Lamp/cover button blinking red, how can I solve my Sony projector?
After a fall from its support, my SONY EX 245 projector is not working anymore. When I turn it on, it shuts down after few seconds and the lamp/cover light is blinking red. Can someone help me on what can be done? I tried to change the lamp without any success. Nothing appears broken inside… Thank you
Posted by matthias disch on
kishnakant chaturvedi
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 307 Answers
The blinking red lamp/cover button on your Sony projector typically indicates an issue with the lamp or the projector's internal temperature. Here are a few steps you can take to try to resolve the issue:
  1. Check the lamp cover: Make sure that the lamp cover is properly closed and secured. If the cover is not properly closed, the projector may not turn on or may turn off after a short time.
  2. Check the lamp: If the lamp cover is properly closed, the next step is to check the lamp itself. Remove the lamp and check it for any visible signs of damage, such as cracks or discoloration. If the lamp appears to be in good condition, try reseating it to ensure it is properly installed. If you have access to a replacement lamp, try installing it to see if the problem is resolved.
  3. Check the projector's air vents: Ensure that the projector's air vents are not blocked or obstructed, as this can cause the projector to overheat and shut down. Make sure that the projector is placed in a well-ventilated area.
  4. Reset the projector: Try resetting the projector by turning it off and unplugging it from the power source for several minutes. Then, plug it back in and try turning it on again.
  5. Consult the user manual: If none of the above steps solve the issue, consult the user manual for your Sony projector for further troubleshooting steps or contact Sony's customer support for further assistance.
If the issue persists, it may indicate a more serious internal problem with the projector that may require professional repair.
Posted on Feb 15, 2023
2answers
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
light is in red means standby mode.
Flashes in red - The projector is in abnormal status. Symptoms are indicated by
number of flashes. Address the problem in accordance with the
following. If a symptom persists, despite having taken measures below, consult with qualified Sony personnel.
Sony projector xga indicate lamp cover
there is an conductor under the cover,
pls push it down ,
and turn on the projector
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
1helpful
2answers
Sony projector 3LCD lamp/cover blink red
When I plug the LCD the LAMP/COVER flsh blinking red light
1helpful
6helpful
2answers
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
1helpful
2answers
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
1helpful
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
AAA TV Service
AAA TV Service
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
