Redi remote control manual for an genessis g506 for sound systemGENESIS G506 REMOTE CONTROL MANUAL1. Battery InstallationThe GENESIS G506 remote control requires two AAA batteries. To install the batteries:a. Remove the battery compartment cover by pressing the release tab on the back of the remote.b. Insert two AAA batteries into the battery compartment with the correct polarity.c. Replace the battery compartment cover.2. Setting Up the RemoteOnce the batteries are installed, you will need to set up the remote for use.a. Press and hold the MODE button for 3 seconds to enter setup mode. The red LED will flash twice.b. Press and release the DEVICE button to select the device you want to control. The LED will flash once for each press.c. When the desired device is selected, press and hold the MODE button for 3 seconds to save the selection. The red LED will flash twice.d. Repeat steps a-c for each device you wish to control.3. Using the RemoteOnce the remote is set up, you can use it to control your devices.a. Press the DEVICE button
Testimonial: "This remote has four batteries and if you like I can send you a picture of the remote but I would like the manual for the redi remote control for an genesis g506 sound system"
you can email me with pictures or cell me and walk me [email protected]. or 973-518-7946
