Computers & Internet Logo
How to Add Month To Date Excel?
Posted by Excel Proper on
ADMIN Andrew
    Top Expert:
  • Computers & ... Master
  • 57,456 Answers
1helpful
In an Excel Spreadsheet, A1 contains date and I need A2 to be yellow if the date falls in the month of May
it is all in the formula setting at the top
download the excel user manual and any excel problems are explained in that document
I need to add a year to dates on excel spread sheet there are more than 440 diffrent dates....Please help?
I assume that the dates you want adjust are in date form and are in regular columns (or rows).
If so, then you can use a formula like this =DATE(YEAR(A3)+1,MONTH(A3),DAY(A3))
where the original date is in cell A3.
You can then copy this formula to calculate all the new dates you need, and then copy the results back over the original dates as VALUES.
1helpful
Calculation of end date in format dd/mm/yy
Assuming you put the start date in cell A1, put this formula:
=DATE(YEAR(A1),MONTH(A1)+15,DAY(A1))
in the cell where the result wanted to be appeared.
P.S.: If this information was helpful, please rate this solution.
1helpful
Converting date of a month to last working day of the month
use the below formula to get the date of the LWD (Monday thru Friday) of the month.
Assumed that if the date in cell A1 is 6-May-2005. then formula will be
=DATE(YEAR(A1),MONTH(A1)+1,0)-(MAX(0,WEEKDAY(DATE(YEAR(A1),MONTH(A1)+1,0),2)-5))
I have a year planner in excel in which first row consist of month jan,feb.... and in the second row days are there like 1, 2,3..... and on the very first column name of employees is there so my task is to...
There is always multiple solutions, but here is one...
Add a row (that can be hidden later if you want) where you have the full date (01/01/09). For this example it will be row "C." Then use Conditional Formatting with the function:
=weekday(C$2,2)>5.
See if this helps.
Need to Add Dates in Excel
Here is one way I just tried:
Say the date purchased is in A1.
You want the Est Life in A2.
In A2 type: =A1+(3*365)
That will add 3 years.
For 5 years: =A1+(5*365)
Try it out!
Note: You will need to format the cells to Custom>mm/dd/yyyy
Work day
Hi Chinnu,
For this you will have to install an Add-in called Analysis Tool Pack.
Kindly follow the below instructions:
1. Open Excel Options (Menu-Excel Options)
2. Click on Add-Ins on the side pane of the Excel Options Window
3. Check to see if Analysis ToolPak is in Inactive application add-in list.
4. If is not, proceed to Step 7
5. If it is in the inactive application add in list, Select Excel Add-ins against Manage and click on "Go"
6. In the add-ins menu check Analysis ToolPak and Analysis ToolPak VBA and click OK
7. Use this formula to find the number of work days excluding Saturday & Sunday in a month
=NETWORKDAYS(start_date,end_date, [Holidays])
In your case give the start date as 1st July and end date as 10th July and Holidays as 0 or 1 (doesn't matter). The answer it will return will be 8 days.
Trust the above helped.
Unable to Change Dates
I am using MS-2007, i got the solution upto some level only.
i can't say exactly whether it is right or not.
my solution is :
first change the settings in ControlPanel/Regional and Language Options.
Click on Customize button/open the Date Tab and set the date format there.
and then proceed with CSV.
Open CSV in Excel and divide Text to coloumns.
Ur all Date Cells will be in particual Format.
and Select that coloumns and right click Format Celss....etc.
Thanking u.
If u found any Douts, Suggestions ,Plzz let me know.
Formula for Date
Make that column fixed and give the variable date and value 26/Month of year/year
That is the logic Can you do that
Fixya?
Functions
The eomoth function returns the last day of the month.
Use EOMONTH to calculate maturity dates or due dates that fall on the last day of the month.
eomonth (1/2/08, 1) will return 31. The number of days in the month.
eomonth (1/2/08, 2) will return 59, The number of days in the month plus the next month (February)
Marvin
Marvin
