Measuring Tools & Sensors Logo
Question about Measuring Tools & Sensors
Snap-on Eco plus shows for example that 3.0 lbs transferred during ISV tank fill then immediately shows the tank having 1 lb 9oz what is wrong?
Posted by Ethan Sprungman on
kishnakant chaturvedi
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 307 Answers
Based on the information provided, it's difficult to determine exactly what is causing the discrepancy between the amount of refrigerant transferred and the amount of refrigerant shown in the tank. However, here are a few potential explanations:
  1. Measurement error: It's possible that there was an error in measuring the amount of refrigerant transferred or the amount of refrigerant in the tank. For example, if the scale used to measure the refrigerant is not calibrated correctly, it could be providing inaccurate readings.
  2. Leaks: If there is a leak in the system, refrigerant could be escaping and not making it into the tank. This could result in a lower amount of refrigerant in the tank than expected.
  3. Temperature changes: The amount of refrigerant in a tank can be affected by temperature changes. If the refrigerant was transferred at a different temperature than the tank, it could result in a discrepancy in the amount of refrigerant shown in the tank.
  4. Software error: It's possible that there is an error in the software used to display the amount of refrigerant in the tank. This could be causing the incorrect reading.
It's important to troubleshoot the system to determine the root cause of the discrepancy and take appropriate action to address the issue.
Posted on Feb 15, 2023
3answers
Looking for Hyundai hd65 cylinder head, big ends and mains torque settings
  1. Tighten the cylinder head bolts in the sequence shown. Using the 4 step torque turn method, tighten according to the following values:
    • Step 1: All to 34 Nm (25 ft. lbs.)
    • Step 2: All to 68 Nm (50 ft. lbs.)
    • Step 3: All to 68 Nm (50 ft. lbs.)
CAUTION: Do not use a torque wrench for the following step.
Step 4: Turn an additional 1/4 turn
  • Step 5: Install and tighten bolts (1-10) in sequence shown, to 41 Nm (30 ft. lbs.) .
  1. Tighten bolts (1-10) again to 41 Nm (30 ft. lbs.) PLUS 1/4 turn in sequence shown.
  2. Install main bearing bedplate to engine block bolts (11-20), and torque each bolt to 28 Nm (20 ft. lbs.) in sequence shown.
Connecting Rod Cap Bolts 54 Nm (40 ft. lbs.) + 1/4 turn
1997 Jetta: Torque settings..vw..the head, fly wheel, big ends.
1997 Jetta3 1800 feul injection
Vibration Damper/belt Pulley
Tighten 20 Nm (14.8 ft lb) Crankshaft Toothed Belt Sprocket Tighten 90 Nm (66 ft lb) + 90° Camshaft Sprocket Tighten 80 Nm (60 ft lb) Main Bearing Cap
Tighten 65 Nm (48 ft lb) FLYWHEEL TORQUE
Torque 60 Nm. (44 ft. lbs.) + 1/4 turn (90°) [1] [1] Always replace bolts.
CYLINDER HEAD TIGHTENING TORQUE [1] :
1st sequence: 40 Nm (30 ft lb)
2nd sequence: 60 Nm (43 ft lb)
Final sequence: plus 1/2 turn (180°)
Here are some additional specifications, thanks
ntake Manifold
Mounting Bolts 25 Nm (18 ft. lbs.) Bearing Cap Nut 20 Nm (15 ft. lbs.) Rod Bearing Cap
Assembly
Tighten 30 Nm (22 ft lb) + 90° To measure radial clearance
Tighten 30 Nm (22 ft lb) but NOT additional 90° TIGHTENING SPECIFICATIONS
Oil Pump Bolt 20 Nm (14 ft. lbs.) Oil Tube To Block 10 Nm (7 ft. lbs.) Exhaust Manifold to Cyl. Head 25 Nm (18 ft lb) Exhaust Manifold to Front Exhaust Pipe 40 Nm (30 ft lb) Water Pump
Cover Bolts 10 Nm (7 ft. lbs.) Mounting Bolt and Studs 20 Nm (15 ft. lbs.) + 1/4 turn (90°) Pulley Bolts 25 Nm (18 ft. lbs.)
Connecting Rod Nuts:
Tighten In Two Stages:
First Stage 30 Nm (22 ft. lbs.) Second Stage turn an additional 90°(1/4 turn)
2answers
Robinair 34788 keeps overcharging the isv how do i fix this issue or how do i find out whats wrong
Robinair 34788 Set Up Operation Part #1 - YouTube
? 6:05
www.youtube.com/watch?v=XW8o5tahLpE
Aug 30, 2013 - Uploaded by OTC TOOLS This video takes the viewer through the entire Set Up and Operation of the 34788. The Cool-Tech 34788 ...
Why can u not fill my isv it will try but shuts off instantly?
If it's a replaceable tank it likely has a check valve to prevent backfilling. If the tank is designed to be refilled you may need a different hose for filling it, check the manual.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
1helpful
Lookin for head torque specs and sequence
Torque sequence ----------- ' 9 7 3 1 5 ' ' 8 4 2 6 ' ----------- Step 1: torque in sequence to 45 Ft/Lbs Step 2: torque in sequence to 65 Ft/Lbs Step 3: torque in sequence to 65 Ft/Lbs again plus 1/4 turn Step 4: Torque small bolt in rear of head to 25 Ft/Lb Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
3.3L
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
12helpful
Robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
I am looking 4 the torque pressures (ft.lbs) on the main crank bearings, and rod bearings on a 2007 Ford 5.4 3 valve engine??? Gerry..............thank-you
mains - vertical bolts first 30 ft.lb. PLUS 90 degrees
pattern frt
8 7
4 3
2 1
6 5
10 9
side bolts
22 ft. lb plus 90 degrees
pattern frt
7 8
3 4
1 2
5 6
9 10
connecting rod caps cracked type rod-rod and caps must be kept in matched sets, recommend new bolts/nuts, spec is 32 ft lb. plus 105 degrees - torque each item to the correct torque then go back and do the degrees. these are torque to yield bolts and the procedure is very important.
4helpful
How do you transfer new refrigerant to tank
Connect fill hose ( Black hose with 2/1'' quick connector located at near the tank strip) to source tank (New R134a refrigeration tank) & make up side down. switch on the machine power switch. Press main menu key then keep pressing up or down arrow key till appear "Tank Refil" on the display screen. with "Tank refill" on screen press YES key. the message will change to ''Checking source tank" for few second then start filling refrigerant to ISV tank. press NO key to exit when you want to stop filling.
Hope this will help you, Good lucl & vote for my solution!
3helpful
2answers
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Top Measuring Tools & Sensors Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
