Televison & Video Logo
Question about Vizio Televison & Video
Vizio V555-H1 tv still works but the screen suddenly now has a white fog over entire screen. Even when the TV is powering up when the Vizio logo appears the black background is no longer black
I've reset the TV to factory settings, unplugged it, held power button down for 5 seconds, ran software updates, adjusted every picture setting
Posted by Edward Baker on
  • Edward Baker
    Edward Baker Feb 16, 2023
    OK we tried an alternative source but it didn't help. In fact when I turned on the TV today, it's now giving me this on the screen (see attached pic). I can still hear audio and it responds to the TV remote but no images. Does this look like a faulty T-Con board? If so how much is the one for my TV?
    Thanks, Ed
ola ola
    Passionate:
    Visited the website for 10 consecutive days.
  • 64 Answers
The symptoms you described could be caused by a few different hardware issues. One possibility is that the backlight system, which provides the TV's illumination, may have failed or malfunctioned, resulting in the white fog over the screen. Another possibility is that the LCD panel may have developed a fault, which can cause discoloration or uneven brightness across the display. Both of these issues are typically not easily fixable through user adjustments or software updates and may require replacement of the affected hardware components.
I also believe that to further diagnose the issue, you could try connecting an external device, such as a game console or DVD player, to the TV and see if the white fog and black background issue persists across different sources. If the issue is present across multiple sources, then it is likely a hardware issue with the TV.
If the TV is still under warranty, you may be able to get it repaired or replaced by Vizio.
It's also worth noting that in some cases, the issue may be caused by a faulty T-Con board, which is responsible for controlling the timing and signals that drive the LCD panel. This is another potential hardware issue that can cause issues with the display.
Do notify me if the solution helped, I will be glad to help you more.
Posted on Feb 14, 2023
My VIZIO TV model V555-H1 that has horizontal and vertical lines on the screen. Now its stuck in service mode color test? How can I get it out of this color changing mode?
Try a forced reboot...disconnect the power cord either from the back of the TV or its outlet, at your convenience. Then, press and hold the power button on the TV for 3-5 seconds. Finally, plug the cord back in and turn on the TV.
Best to you.
1helpful
Vizio 55 in V555-G1 LTCDYILW Top of screen is black
This model TV has what's called local dimming, on most brands LED lights are wired like christmas tree lights, take one bulb out the set is dead but on most Vizeo sets each strip has it's own power sourse, chances are some of the strips are bad and need replacing but if you replace one replace them all
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
No picture or sound
Its the main board 90% of the time when a vizio has that symptom.
2helpful
Suddenly no picture only a black screen.The tv has power the little vizio turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv...
Look through the ventilation slits at the back of the TV with the room lights out. If you do not see white light light bleeding through the back, you have a back light failure. It could be the inverter circuit which lights up the CCFL ( cold cathode fluorescent lamp ). You will need professional help to replace it and could cost you about 70 to 100 $ to fix.
1helpful
I plug the tv in and there is no power
Go to MENU at the Tv turn on the logo light option on.
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
