Kitchen Ranges Logo
Question about Frigidaire Kitchen Ranges
How do I remove the bottom drawer of a Frigidaire gas stove, model FGF326ASE?
Posted by Larry on
ola ola
    Passionate:
    Visited the website for 10 consecutive days.
  • 64 Answers
Posted on Feb 14, 2023
Testimonial: "Perfect! Thank you!"
How can I remove the broiler drawer on my frigidaire gas range? A pyrex dish broke while halfway out of the oven and there is glass everywhere. I'm wanting to remove the broiler drawer so I can vacuu
I appreciate your inquiry, Tiffany Robinson!
I understand that you need assistance in removing your broiler drawer on your Frigidaire range. Could you provide the model number, please? With the model number I would be able to provide you further assistance. You can locate the serial tag (which lists your model number) on the door frame behind the bottom drawer. Once I have additional information I would be able to assist you better. I look forward to helping you. -Matt
1helpful
2answers
My Frigidaire 30" gas stove is not leveled from
If you remove the bottom of the range, where the pan storage drawer is, you will see the leveling legs there, and you can use those to level the machine. Don't use pliers if you can avoid it, find an adjustable wrench or an open end wrench, the ones on mine are 7/16th. You can use a measuring cup filled to a line level, and place it on the stove as you move the legs, then you can better adjust them. Do so until the water levels off at the line you filled to. A final test will be to place a flat pan and only drop a couple drops onto it, and see if this runs to one side or the other.
Hope this helps, Please rate and comment, Thank You
Joe
2helpful
I bought gas cook stove used. I have propane gas & I don't know what kind of gas the stove was set up for. When oven is on it smells strongly of gas, food cooked in oven has black soot on it and flame...
There is a regulator behind the bottom drawer remove the drawer.look in the back you will see a silver box that the oven fuel rail is on just below the rail there is a brass fitting that needs to be turned clockwise till it stops it can be hard to turn some times but turn it till there is no clearance between the nut part of the valve and the silver box then you can start your oven and it should work fine you can also adjust it to get a little more flame if needed.
4helpful
I have a stove and it is frigidaire and it the bottom drawer back clips fell out and it just drops when I close it how do I put the clips back in
Just happened to us and my wife figured it out. They go on the bottom of the side panels of the drawer at the back. The hook part sticks inside the drawer.
Levers on side of stove
They are for removing the drawer from the cabinet.
Charlie
3answers
Oven Fridgidaire Model FGF326ASF
You replaced the EOC? Thats what the issue is
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Can you give me easy install directions?
are yours and hers both freestanding? (do they both have a drawer at the bottom?) if so measure the width to see if hers will fit. if so, turn off the circuit breaker to your stove. remove the drawer of your stove. do you see the plug? unplug it. now just slide it out toward you being careful not to damage the floor. installation opposite of removal.
Hope this helps
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
