Question about Bose Audio Players & Recorders
The Bose 901 speakers require the use of a specific equalizer that is designed to optimize their performance. If you have a Bose 901 equalizer, you will need to connect it to your Lafayette 3500 receiver in order to properly use the speakers.
Here are the general steps for connecting the Bose 901 equalizer to your Lafayette 3500 receiver:
Note: It's important to use the Bose 901 equalizer specifically designed for the speakers. Using a different equalizer or not using any equalizer at all may result in poor sound quality or damage to the speakers.
Posted on Feb 15, 2023
Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
