Panda 2.65Cu. Ft. compact dryer, model: PAN865W stopped working?
It worked fine before it sat in the garage for about a year. gave it to a friend and it will not work?? When plugged in... the controls light up for about 3 seconds, then nothing.... completely dead. Unplug and repeats the same ???
PLEASE HELP!!!
THANK YOU!!
Scott
(9*4) ***-***4
Habit-Forming:
Expert
Re:
It is possible that the dryer has a faulty power cord or a faulty control board. If the power cord is faulty, it will need to be replaced. If the control board is faulty, it will need to be replaced as well. If the dryer is still under warranty, you should contact the manufacturer for assistance. If the dryer is not under warranty, you may need to contact a local appliance repair technician for assistance.
It is possible that the issue with your Panda 3.75 cu ft portable dryer could be caused by a blown fuse. The fuse for the dryer is usually located at the back of the unit or on the wall near the power outlet. You can try to replace the fuse to see if this resolves the issue. Additionally, you could also check for any loose connections on the control panel and clean the lint filter.
dryers always have a fan, without it working it will overheat and the over temperature thermostat will switch off. You could also have plugged filter which is redistricting air flow, check this first.
Hi, could not find a users manual for sonya SYD-60E dryer so that I could order a thermal fuse, as the dryer would not run, however, I found a blog that suggested that Avanti, Sonja and Panda were made by the same manufacturer, I found a phone number for Avanti, ordered the thermal fuse for the only model that Avanti sells, which cost $10.00, and in about 10 business days the part arrived, we installed it in our Sonya dryer and our dryer works beautifully! Hope this helps
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
