You can't. It has an anti-theft device. The days of boosting a car with a couple of wires ended in the 1980s! You have to fix the problem, not find a way around it.
The PassLock system was designed to prevent vehicle theft by disabling fuel to the engine if ... Chevrolet Silverado 1997-2004. Chevrolet Sport Van 1997-2000
REBUILT WITH LIFETIME WARRANTY GM Passlock Anti-Theft VATS module. PART NUMBER 16264985. THIS PART IS OBSOLETE AND UNAVAILABLE AT ...
Rating: 5 · 2 reviews · US$149.99 · In stock
Is there a security light lit on the dash or anti-theft system symbol ? If it is the anti-theft system your going to have to take to the dealer ,sorry but you don't have the diagnostic equipment to fix this .
my.cardone.com/techdocs/PT%2078-0004.pdf Passive Anti-Theft Systems (PATS), also called Ford Securilock, is a vehicle security ... Module (PCM) on a PATS-equipped vehicle, a parameter reset or relearn ..
? 9:25 www.youtube.com/watch?v=pJBMgrW7MQU Feb 12, 2014 - Uploaded by FordTechMakulocoI'm having that issue now with my 2005 Ford Explorer any other ... I am having alarm problems so I never ....
Is the Security light on? Could be too many things to list here. Step 1. Scan for codes. If no codes, see if it's losing spark or fuel or both. If it's losing fuel, it might be the pump or relay or wiring or computer. If no spark, it could be cam sensor or computer. Security light on means the key or anti-theft module has a problem. If equipped. Kind of what it sounds like, the computer shuts off the spark when the theft module does not detect the proper key chip.
i forget my security code in anti-theft.so i cant change my sim card.please solve my problem.my handset model is nokia C6-00. IMEI:355398046288303 CODE: 059C205 FCC ID: PYARM-612 IC: 661V-RM612 my gmail adress:[email protected]
i forget my security code in anti-theft.so i cant change my sim card.please solve my problem.my handset model is nokia C7-00.
IMEI:357395041198758
MATERIAL:002S3F4
Your anti theft is not working properly you will need to have a scan completed to find the source of the problem it could be one of several problems a guess would be a excessive amount of money spent unnecessarily.However scan will pin point the problem and allow you to take it from that point unless you have a on board scanner you might have to take your car in for this to be completed due to anti theft protection your car is equipped with serial numbers from factory no to cars are the same and neither is the security code for your anti theft system dealer holds the information on this you will need proof of owner ship to have this done this is one of those things with anti theft one way they are great but in this case not so great.
When you disconnect/replace a car battery, your radio anti-theft security system will be triggered: consult your car user manual on how to reset the anti-theft security for your particular radio/audio system: you will need to enter a specific 'security code' that should have been provided when your car or car audio system was bought.
The best way to protect both the screen and computer is to use an anti-theft cable. The cable is secured to the screen, computer and the desk using very strong self adhesive anchor pads and is then padlocked to the desktop.
