Televison & Video Logo
Question about Samsung Televison & Video
Hi i would like to know if i could project my Samsung A32 to my Sansui SV21E11G via Aux Cable?
Posted by Thabang Thabethe on
ola ola
    Passionate:
    Visited the website for 10 consecutive days.
  • 64 Answers
An aux cable is designed for transmitting analog audio signals and cannot carry video signals. The Sansui SV21E11G TV also does not have any built-in features for screen mirroring or connecting to mobile devices wirelessly, so you will need to use an external device to connect your Samsung A32 to the TV.
Using an HDMI cable is a simple and straightforward method to project your Samsung A32 to your TV. HDMI is a digital signal that can carry both video and audio signals, and most modern devices come with an HDMI port. To use this method, you will need an HDMI cable and an HDMI adapter or connector for your Samsung A32, if it doesn't already have an HDMI port.
Wireless screen mirroring devices, such as Chromecast or Miracast, allow you to wirelessly project your smartphone's screen onto your TV. These devices use Wi-Fi Direct technology to create a direct connection between your Samsung A32 and the TV, and they can mirror the contents of your phone's screen in real-time. To use this method, you will need a compatible screen mirroring device, a Wi-Fi network, and a compatible TV with an HDMI port.
Posted on Feb 14, 2023
2answers
Can I use my Samsung A32 galaxy phone as a remote for a magnavox sdtv converter box
You can't use the Galaxy A32 as a remote control for any IR controlled device directly. The A32 does not have an IR blaster. All of the digital to analog tuner converter boxes that I know of only had IR remote controls. You can find IR blasters on Amazon that have a wi-fi hub that can be paired with a cell phone to control TVs and other A/V hardware. I've seen mixed reviews on these devices.
I wish that I had better news for you.
Samsung Galaxy A22 VS A32
Which phone is better Samsung a22 or a32?
If the display and battery life are more important to you, then choose the Samsung Galaxy A32. But if the camera is more of a priority - go for the Samsung Galaxy A22.
Compare Samsung Galaxy A32 vs Galaxy A22: which is better?
https://nanoreview.net > Home > Smartphone comparison
Search for:
and more
https://www.google.com/search?q=Samsung+Galaxy+A22+VS+Samsung+Galaxy+A32
2answers
My sansui tv has an interuppted sound. How do I fix it
It's all electronics so unless you call the sansui customer care not much can be done. If you have a audio system then connect the audio out from TV to aux.in of your sound system. That way you can still hear the TV audio. I hope the audio out of TV still operational!!
How do I hook up my samsung home theater system to my sansui tv to get surround sound when watching the tv
if your tv has audio out jacks connect them to the audio in jacks on your samsung system. it may say video 1,video 2,or aux in. use this step if you have a cable box as well.
1helpful
Samsung z310
You have to press the AUX button and set the HTS unit to D. IN (DIGITAL IN)
AUX 2 only works for the regular red & white audio cables.
Hope this helps!
How to hook up a sansui classique 350 reciever to a tv
Are you wanting to play he audio from your tv through you Sansui Stereo. If you have audio outs on you tv then connect them to the aux input of the receiver. If you ae using a cable box r sat reciever you can connect the audio out from these devices to the aux or any input other than phono input of your Sansui receiver.
Cant connect samsung RTS-HE10 home cinema to my samsung 40" tv, which has 1 HDMI port. I also have sky hd
Connect the RTS-HE10 via HDMI to the TV and the Sky+ via scart to the TV. Then get a stereo RCA to 3.5mm jack lead and connect from your TV's stereo RCA output (red/white) to the Aux 3.5mm jack (like a headphone socket) on the RTS-HE10. Select Aux on the RTS-HE10 when you want to listen to whatever is on the TV.
2answers
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Sansui TVM1316
try channel 65 and connect via antenna cable.
 Grubhead
Grubhead
