Question about Yamaha Audio Players & Recorders
How to set channels for stations so they are locked to my stations
Can't remember how to preset stations on my yamaha HTR 5660 so they are programed to the remote
  • Yamaha Master
  • 6,609 Answers
You can let the Yamaha HTR-5660 set stations for the FM band automatically. To manually set the station in one of the memory banks, first tune to the desired frequency (AM/FM band). Press Memory on the receiver. The memory light will flash for 5 seconds. Press the A/B/C/D/E to select the desired memory group while memory light is flashing. Make sure that you see the colon after the letter. Use the preset/tuning left right arrows to select the memory bank (1-8) to use in that group. This also needs to be done while the memory indicator is flashing. Press Memory to save the frequency in the desired memory location. If that memory group and bank had a station frequency stored in the location, it will be erased and the new one saved. If you do not finish the procedure before the Memory indicator stops flashing, you will have to repeat the steps.
You can recall the stored stations from either the remote or the receiver by pressing the A/B/C/D/E button multiple times (as needed) and the preset/tuning buttons. On the receiver, the A/B/C/D/E button is also the Next button. On the remote, it's the Menu/Set Menu button.
The steps for presetting stations is shown starting on page 33 of the manual, https://www.manualslib.com/manual/197490/Yamaha-Htr-5660.html?page=37#manual . The entire manual is available here: https://usa.yamaha.com/files/download/other_assets/3/319793/01_om_htr-5660.pdf .
I hope this helps.
Posted on Feb 05, 2023
1helpful
How to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
When watching cable tv we are not getting any sound from the speakers. We do get sound from all the speakers when watching a dvd or listen to the stereo. I have a Yamaha HTR 5660 receiver. All the cables...
Your best bet is to hook all your video components directly to TV, using your TV's menu to choose what you want to watch, and then hooking reciever to TV via digital optical out from TV to digital optical in on reciever. From what I read, your reciever has 6 digital optical inputs. Anyway, try running, at least, your cable box to TV, best by HDMI, the run digital optical out to reciever. Make sure you go throught he recievers menu to make sure you have he right channel selected for audio.
2answers
Well i have a yamaha natural sound av receiver htr-5660 and ive connected 200 watt speakers and my problem is my tweeters are only working and i would to like know step by step to on how to get the...
"200 watt speaker" is meaningless. What brand and model? Be advised that stripping parts from an all-in-one audio package for redeployment with 'standard' audio components doesn't guarantee compatibility or safe function.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5660-Receivers-manual/id/394ci074/t/2/
The amp has selectable impedance. See page 16.
1helpful
3answers
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
1helpful
Our HTR-5660 is about 5 years old. Recently it
I solved the problem by ensuring the Impedence selector was either all the way to the left or all the way to the right, as instructed in the manual.
Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Tuner
Hi Dude
Presetting channels for radio stations is generally all the same on most systems. Select the frequency you want and then HOLD IN the preset button you want until it locks to the frequency into the new preset. Good luck, and happy presetting :)
regards
Graeme
Open Questions:
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
