Televison & Video Logo
Where can I get a replacement remote for a Electcom DVD HDMI player model ELC-225
Posted by LaDale McCaleb on
john h
    Top Expert:
  • Televison & ... Master
  • 28,867 Answers
Order online
Posted on Feb 15, 2023
I have a Magnavox universal remote model MC345 and I need the code to program it my ONN HDMI DVD PLAYER W/TTSMODEL: ONA19DP005 HELP PLEASE jacqueline
That make model number is a mess. You need 'make' and numerical model number only.
Here are your codes
https://myuniversalremotecodes.com/onn-dvd-universal-remote-codes/
Usually you can but replacement remotes, but this is Walmart's own bargain basement brand from China, made at the lowest cost point and the highest profit. Quality is not a consideration!
https://www.google.com/search?q=ONN+ONA19DP005+remote
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
3answers
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Want to activate HDMI and surround speakers without remote?
You will need the original remote access these functions, try www.sony.com contact customer support and the technical department, also try www.ebay.com type make and model of player and scroll through the list.
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Pioneer DVR-225 Set Up Code?
I believe it is one of these three:
021, 013 or 048
Hook up HDMI to Viewsonic pull other cables and I can't get pictu
you are right the hdmi cable does replace others for the input , have you tryed using your remote to switch your mode to the one that is used for hdmi ? example my sony has my dvd player hooked up to it with hdmi and to use my dvd player or see the screen i have to hit the mode button on my remote till i see a picture with my dvd player on, hope this helps please rate this.
Top Televison & Video Experts
Marvin
Marvin
