Computers & Internet Logo
NET HELPMSG 2182. System.Management.Automation.RemoteException
Posted by Justin Pierce on
Dhemit Caruban
The error message "NET HELPMSG 2182. System.Management.Automation.RemoteException" typically occurs when there is an issue with executing a remote command in PowerShell. Here are some steps you can try to resolve this error:
Check network connectivity: Ensure that you have a stable network connection and that the remote computer is accessible. You can do this by pinging the remote computer to see if you get a response.Check remote execution policy: Make sure that the remote execution policy on the target computer is set to "RemoteSigned" or "Unrestricted". You can check the remote execution policy by running the following command in PowerShell:
Get-ExecutionPolicy -Scope RemoteMachine Run the command as an administrator: Some commands may require administrative privileges, so try running the PowerShell prompt as an administrator and then executing the command again.Verify the remote computer name: Ensure that the remote computer name is correct and that you have permission to access it.Disable the Windows Firewall: If the Windows Firewall is enabled on the target computer, try disabling it temporarily to see if it is causing the issue. You can do this by running the following command in PowerShell:
Set-NetFirewallProfile -Profile Domain,Public,Private -Enabled False Enable CredSSP authentication: CredSSP (Credential Security Support Provider) is an authentication method that is used for remote commands. You can enable CredSSP authentication by running the following command in PowerShell:
Enable-WSManCredSSP -Role Client -DelegateComputer * If none of these steps resolve the issue, it may be necessary to consult the error logs or seek assistance from a professional administrator.
Posted on Feb 12, 2023
1helpful
I need topics for vb projecttt
some of them
hostel management
online reservation
airline resrvation
railway reservation
inventory management
hospital management
office automation
libraray management
this are the basic topic on vb project.
8helpful
3answers
2answers
PROJECT TOPIC FOR DIPLOMA
  1. Customer Service Back Office Project
  2. Training Tracker System.
  3. Sales Tracking Software
  4. Travel Management System (TMS)
  5. Student Fee Management System
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
1helpful
2answers
Source code for Inventory management system in ASP.Net
Sir,
Click this link and download the code
Thanks Good Luck
Appreciate to rate as "Fixya"
Marvin
Marvin
