Question about Pioneer Audio Players & Recorders
Pioneer PL 640 variation speed? Fix? - Pioneer Audio Players & Recorders
Anthony
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 419 Answers
If your Pioneer PL 640 turntable is experiencing variations in speed, there are a few potential causes to consider. Here are some steps you can take to troubleshoot and fix the issue: Check the belt: The belt on the turntable may have become stretched or worn, which can cause variations in speed. Inspect the belt for any signs of damage or wear, and replace it if necessary. Check the platter: The platter may be dirty or have accumulated debris, which can cause it to spin unevenly. Remove the platter and clean it thoroughly, and make sure it is seated correctly on the spindle. Check the motor: The motor may be malfunctioning or dirty, which can cause variations in speed. Remove the motor and clean it, and check it for any signs of damage or wear. If necessary, replace the motor. Check the pitch control: The pitch control on the turntable may be dirty or malfunctioning, which can cause variations in speed. Clean the pitch control and make sure it is working correctly. Check the power supply: The power supply may be providing insufficient power to the turntable, which can cause variations in speed. Check the voltage output of the power supply, and make sure it is within the manufacturer's recommended range. If none of these steps resolves the issue, you may need to take your turntable to a professional repair technician for further diagnosis and repair.
Posted on Feb 24, 2023
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
PL-L50 Pioneer direct drive turntable playing records as if it had a bad belt speed variations in playback, but direct drive has no belts of course. What could be making my records playback speed...
If there is a speed adjustment for 45 and 33 rpm records the contacts or pots need to be sprayed with some electronic cleaner to remove any dust. This is done by removing the bottom of the player and finding the control knobs inside. Electronic cleaner can be found at Radio Shack for around $10 for a large can. It does not take much. Just spay inside the control knobs inside the unit. You will find a small hole where you can put the spray tube that comes with the cleaner. Work the "pots" or knobs back and forth several times to loosen any residue inside the knob casing. Be careful not to shock yourself by removing the bottom. If you are not use to working on electronics it may be better to let someone else with more knowledge tackle the job.
1970's vintage Pioneer PL-630 turntable w/ speed variation proble
THIS IS HOW!!
http://www.audiokarma.org/forums/showthread.php?t=92333
5helpful
Pioneer PL-630 turntable won't hold correct speed with the quartz lock on or off. I cleaned the switches with no change,speed still varies.
Replace the speed selector switch, if you can still get one...They were prone to oxidation caused by gasses emitted from the rubber foot close by... The Pioneer remedy was change switch AND rubber foot for a neoprene one
2answers
I have an old Pioneer stereo auto turntable PL-5.It is rarely used and worked fine until my grandson started to turn the turntable by hand and I think backwards.Now it speeds up and races.Can this be fixed...
if the speed is constantly fast the drive belt may have ridden up on the top part of the motor pulley.inspect and refit.if the speed varies check operation of 33/45 switch.
Pioneer PL-12D TURNTABLE. Plays too fast.
Judging by your message I guess it's a secondhand machine, you have either been given or purchased. I suspect that someone might have played around with the speed preset to the motor. Take a look around the deck see if you can find it, sometimes there are two, one for each speed. They should correct it, unless something has gone.
Where can I buy Pioneer turntable belts in Pietermaritzburg, South Africa?
My Auto Return Stereo Turntable , PL - 640, Quatz - Direct Drive is not playing, could you give me contact no around Pretoria or Midrand or even Johannesburg where i can send it for repairs
Open Questions:
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
