Question about Xerox Office Equipment & Supplies
Invalid black for Xerox Phaser 6140 after replacing new toner
Hi Is there any hope to fix this error " invalid Black" showed after replacing the cartridge with comp?table one.
jayreaux
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
The cartridge may not be compatible. I think the Xerox brand part number for the black toner is 106R01480.
Posted on Feb 13, 2023
Machine Xerox printer Workcentre 3210. Invalid Toner message continues, even though the toner has been removed and reinstalled.
You must use Genuine Xerox supplies from Xerox, especially if you are on a lease and supplies deal. You slip a refilled or 'compatible' replacement toner from 'The Toner Guys', the machine locks you out until reset by a Xerox tech.
https://forum.support.xerox.com/t5/Hardware/Invalid-Toner-Cartridge-error-Workcentre-3615/td-p/199538
and although it is a different model, it is the same series
Turns out the WorkCentre 3615 has two types of toners - None Metered 106TO2722 and Metered 106RO2724. Both toner boxes say WorkCentre 3615. You must order the correct one or you will get this error and the machine won't work at all. Who knew? Xerox admitted they sent us the wrong one, so they are offering to fix with a code over the phone.
https://www.google.com/search?q=xerox+workcentre+3215+invalid+toner+cartridge
1helpful
My xerox 6600 keeps saying "invalid black" when replacing cartridge
The CHIP on the NON OEM cartridge is NOT current with correct firmware and as a result the cartridge(s) will NOT reset that a new cartridge has been installed.
Future hint...do NOT update as working printer drivers "ever"...as this is one way that the OEM's thwart the aftermarket TONER usage.
Good luck
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
09-800 Invalid Toner Cartridge Message
Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
1helpful
My xerox phaser6110 shows a massage "invalid black toner" while using a generic toner. what could be the problem?
The toner has a chip inside. The chip could be damaged or not reset properly. Please bring it back to where you bought it from to get it exchanged.
22helpful
How to fix invalid black message after replacing a toner
how to fix invalid black message after replacing a toner And I have the same problem. I buy 4 new toners and for each one i get notice from xerox 6125 invalid black, or invalid yellow. What do I need work?
I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
3helpful
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Top Xerox Office Equipment & Supplies Experts
Gary
Gary
Clive
Clive
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
