Question about Yamaha Audio Players & Recorders
Can i hook up my bose 901 equaliser to a Yamaha A S701 amplifier?
Posted by donal on
Sharifullah
    Habit-Forming:
  • 103 Answers
Yes, you can hook up your Bose 901 equalizer to a Yamaha A S701 amplifier. Make sure to use the appropriate cables and connectors to ensure that the signal is transmitted properly. Additionally, make sure to check the amplifier and equalizer settings to ensure that the sound is balanced.
Posted on Feb 05, 2023
  • donal
    donal Feb 05, 2023
    Can you please be more specific because most sources ive researched said it cant be done because theres no pre-out or monitor switch on this particular model?
How to hook up my bose 901 to h&k 1710s
The Harman Kardon AVR 1710S is a 7.2 channel 700watts amplifier.You can connect the Bose 901 speakers to the front speaker connections at the rear of the amplifier for maximum performance
How to connect bose 901 to yamaha htr -6090
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 35 watts per channel out of the receiver to power the 901's
Just purchased Sony DA5800 ES reciever will my Bose 901 speakers work with this? Need help
Bose 901 speakers are designed to use with the Bose equaliser patched between the pre-amplifier out and power-amplifier in of your receiver. Having said that, Bose did not invent EQ, neither is EQ a mystical process. Not sure which series 901s you are talking about, but I would definitely be experimenting with the built-in EQ supplied with your Sony DA5800 ES. The manual says you have +/- 10 dB of adjustment for treble and bass for each of the surround channels. That is not really adequate in my opinion, not only would I be seeking +/- 15 dB, but I would also like to be able to apply those adjustments at frequencies chosen by me, not just 'treble' and 'bass' To use the Bose EQ, it needs to be patched between a preamp output and power amp input. The Sony DA5800 ES has preamp outputs, so you could use these (Note that the built-in EQ is disabled when using these outputs) In this case you could either feed the signals back into the Sony (post Bose EQ) perhaps using a different 'Zone'. As an alternative option, you could power your 901's with a stand-alone two channel power amplifier. Then you get the full benefit of the Bose EQ as well as the surround sound from your Sony (front L+R speakers off) It all sounds like a lot of fun. Happy listening! Cheers, Don.
2answers
How to connect my bose 901 to rx-v2200
You can do this however you will need a separate power amplifier.
See notes here: https://deercreekaudio.com/blogs-%26-updates/f/connecting-your-eq901-to-an-audio-video-receiver-avr
  1. Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right
  2. Connect your 901 speaker to the power amplifier outputs
The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes.
1helpful
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer ' eHow.com http://www.ehow.com/how_4813156_install-bose-equalizer.html#ixzz19vfsJTQu
    1helpful
    2answers
    Can I hookup a Bose 901 EQ to my receiver and amp?
    Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
    Put that old amp back to work.
    This is exactly how mine are connected.
    For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
    How do i hook my bose 901 equalizer into deno
    The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
    Beemer530
    2helpful
    Latest model surround receiver for bose 901 speakers VI
    I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
    Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
    Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
    A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
    What kind of amplifier and other accessories are recommended for bose 901 speakers
    I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
    Open Questions:
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Colin Stickland
    Colin Stickland
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
