I have yaesu ft411e.few year back ,i found some digits on lcd not showing properly, rather not key pressing.i opened it ,did try to clean rubber ,etc.mean while i found ,FFC cable was broken after 3,4 year,i again took in hand.now i resolder the cable , check all point continuity.i was in fear, if some point among 24 might have short circuited, so ,though my battery was drained and no 12 volt power supply ready ,so , I wanted to test with 9 volt battery .but the result is , small indicator LED flash for a second .i do nothing, but one time i notice ,sound was coming as like when no signal and squelch fully opened.but no display.actualy radio was ok when I first opened ,not it behaved like this.pls help me anyone.i am not a expert reparing the things After posting this question,one update that ,sound of open squelch is hear continuously, key pad working as it sounds beep.blindly i entered one local frequency.any then transmit same frequency from another set it sences ,means if lcd can be corrected ,i can do more.one more thing, this time i connected the rig with 12 v power supply,means low voltage also make problem.so, by this my question is now for lcd not illuminated.
It sounds like there may be an issue with the LCD display on your Yaesu FT411E radio. If the display is not working, it may be necessary to replace it in order to restore full functionality to the radio. You may be able to find a replacement LCD display online through electronics parts suppliers or through radio repair shops that specialize in Yaesu radios. Alternatively, you could try contacting Yaesu directly to see if they have any replacement parts available. If you are not comfortable with repairing the radio yourself, it may be best to take it to a professional radio repair technician who can diagnose and fix the issue for you.
Posted on Feb 24, 2023
