Televison & Video Logo
Why does my Ecco tv say list is empty ?
Openview box went off and just says channel list empty and when u want to reset it It says failure no signal or quality
Posted by Louise Santucci on
ADMIN Eric
    Top Expert:
  • Televison & ... Master
  • 37,872 Answers
Sounds like your having issues with the decoder box.
Try checking all connections and re boot the decoder/router.
Posted on Feb 04, 2023
Testimonial: "Thanks so much!"
My magnavox 27 in TV will not let me select channels after I went to auto channel select. How do i reset it?
Be sure you have a signal connected to the RF [antenna jack] Connector! You may also have a corrupted EEprom. This is a common problem for this TV. But try the programming and be sure your menu says you are programming for Cable or Over the Air signals. And if you have a satellite or cablebox you shoud be on channel 3 or AV 1 or 2...in this case you need to do nothing..as the channels you select come from your satillite or cable box.
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
2helpful
2answers
Panasonic DVR, loss of TV Guide on-screen program listings
I had the TVGUIDE listing through my GE TV and it came across with a notice that they would no longer be putting out the listings. That was last year and the listing never showed up again. Your DVR may be recording digitally but if you can see it on a analog tv, it is using a analog turner and you will need a converter box to record once everything goes digital.
Most of the digital converter boxes come with a guide built in. I have the Magnavox and the Zenith and they work fine. You will need two converter boxes, one for the DVR and one for the tv, if you want to watch the tv and record a different show at the same time.
I would hook them up by splitting the antenna wire to the tv and the DVR. Then I would use the RCA plugs to connect the DVR to the TV and use the Input setting on the TV when I want to watch the DVR. You will have to set the converter box to the channel that is playing the program you want. The DVR will be set to channel 3 or 4 (whatever channel the converter box is set on to broadcast on) to record on, not the broadcast channel. Make sure the power saver on the converter box is set to off or the converter box will turn off after a couple hours and you will get no picture for the dvr to record on.
The digital signal is being sent over the air usually over UHF channels. It sent digitally but will be picked up by your antenna in the same way it picks up the analog signal thus there is no difference. There is no such thing as a digital antenna, thus a antenna from a Home Depot will work fine. I needed a outdoor antenna but the picture quality is the same as cable. Just make sure the antenna can pick up UHF and VHF signals.
Hope it helps!
1helpful
Local channel went digital, lost signal.
You need a digital to analog convertor box to recieve the digital signal.
All UHF+VHF signals will be digital starting in June.
Thanks for using FixYa - a FixYa rating is appreciated.
5helpful
6answers
Recorder is not showing tv listings
I spoke with Toshiba tech support today (800-631-3811). They have an advanced services team that focuses on TV Guide On Screen. Learned the following:
- The TV Guide On Screen signal is updated 4x / day and is broadcast by your service provider
- The broadcast channel varies depending on what the service provider chooses (though typically a major network or PBS station)
- TV Guide On Screen has been doing some reprogramming and updates recently and this has resulted in many sporadic outages
If you ARE not receiving your listings, it's one of two things - either your DVR or the signal from the cable company.
- If you are having issues, call Toshiba and let them know, they will walk through some basic troubleshooting to narrow down if the problem is the DVR or the TV Guide On Screen signal.
- If the issue is the TV Guide On Screen signal, they will be able to report the issue to TV Guide On Screen and let them know their is an issue.
After that - it's in someone else's hands!
9helpful
7answers
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Top Televison & Video Experts
Marvin
Marvin
