Canon Ir 3300 Black & White Copier Logo
Question about Canon Ir 3300 Black & White Copier
Canon ir 3300 print out is faint - Canon Ir 3300 Black & White Copier
Posted by Germain Yaw Chikpah on
ADMIN Andrew
    Top Expert:
  • Canon Master
  • 57,080 Answers
Turn the power off at the wall and remove the plug. Remove the toner cartridge and tap it on one end and then on the other. Tap the cartridge horizontally to settle the toner and then replace the cartridge in the machine. Plug back in and try again. The toner may in fact be empty, but doing that will usually give you some extra time and copies. Worst Scenario in the video!
https://www.google.com/search?q=Canon+ir+3300+print+out+is+faint
Posted on Feb 09, 2023
2answers
Canon ir-c2220i Faint Print
A feint print is usually caused by a blocked or empty toner.
4answers
2helpful
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
53helpful
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
12helpful
2answers
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Clive
Clive
old marine
old marine
