Kitchen Appliances - Others Logo
Question about Kitchen Appliances - Others
Where can I get a instruction manual for a 5 piece Prep & Store set please?
Posted by Sherry Blevins on
ADMIN Andrew
    Top Expert:
  • Kitchen Appl... Master
  • 57,371 Answers
Question edited for a lot more clarity, and changed the Spanish gentleman 'Manuel' into the instruction book 'manual'.
Question moved From Cars and Trucks as a GUESS to Kitchen Appliances.
All questions need 'Full 'make model (what it is)'. Let me know the maker. Click Comment under this post and I will try and find it.
https://www.google.com/search?q=5+piece+prep+%26+Store+set+instructions
Posted on Feb 03, 2023
Prep work before I coat floor
My friend is a part time mechanic he gets his solutions from www.reliable-store.com
he gets from their every single detailed info, instructions etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
Can't program the remote on toyota sequoia?
get a repair manuel at the auto parts store they are cheap.
1helpful
My A/C was working fine yesterday morning. But on the way home stopped at a store for 5 mins came out started car and the fans stopped working No air at all is coming out no matter what setting it is on.
It sounds. Like the first thing to do is look in your car Manuel or fuse box, should be mark as ( fan) and check fuse. I believe you just blew a fuse.
I need the step by step process in replacing the timing gears and chain
The very best advice I can give on this one is to buy a Haynes manuel for your vehicle. It will give you step by step instructions for about $20. Don't buy the Chilton manuel. Make sure it's a Haynes. You should be able to pick one up at your local NAPA store or even order it online through Amazon.com.
Worth its weight in gold!!!!!!!!!!!!!!!!!!!
1helpful
How to install a front bumper for a 1996 Honda accord sedan
Installation of a front bumper can be complicated. These helpful instructions may help a person with this task. If you choose to install a bumper yourself, please be cautioned that professional installation is always recommended. Please confirm before you start that your safety equipment has been applied to you, your car and your new bumper. These 10 easy steps can make a difficult install relatively easy.
The following steps are detailed instructions that you can follow. It is very important that you make sure to read each step carefully and completely:
1. Look closely at the new bumper and your car for screws, bolts and clips. Remove these pieces from your existing front bumper and place them in a safe area. Follow this by the full removal of the cars current front bumper.
2. Next, test the fit of the new front bumper. Make sure that nothing hinders with the placement and fit on the car.
3. If the fitment is correct the installation process may move forward.
4. If the fitment is incorrect then the removal or repositioning of certain components, such as reinforcement bars may be required. This is because every car is different. If this is the case remove the element and test fit the front bumper again. This should be done with caution and is done at the installers own risk.
5. Most of the time the new aftermarket bumper is placed the exact way the factory piece was. The most important key to great fitment in installation is the drilling procedure. The holes should be drilled in the places that will give the piece a great fit. Usually, these holes will be drilled in the same place as the factory bumper. At this point only mocking is required.
6. When the bumper is in place, shaving or filing maybe required. Many parts will require this because certain areas are made with more material to lower the risk of damage. Also, if a car has been in an accident or previously modified, this may cause additional sanding, cutting or filing.
7. Now that the front fits well, be very precise and drill the holes.
8. Prepping for paint is what needs to be done after the holes have been drilled. Depending on what material the front bumper is made of will determine the steps for prepping.
9. After the piece has been painted, clear coating may be appropriate.
10. Make sure there are not any leftover parts and that everything is secure. After this is done, your front bumper installation process is complete.
1helpful
Can i paint my dashboard and doors on my 2004 impala ss. and what type of paint should i use?
U can paint them, u must use a special paint that is flexiable and designed for plastic trim, u must also buy a special cleaning and prep cleaner that removes all dirt and oil residue , if u don't follow the instructions exactly the paint will come off very quickly, for information on the products u need contact an autmotive paint supply store, body shops can give you the name of a good one in your area, u can also order from several firms on line, just do a google search
Step by step Instructions for 97 blazer heater core
Try a Hanyes Manuel from an auto parts store
1helpful
How to replace tag light on 2004 camry my manuel says not to try go to dealer.
very easy 5 minute job, open the trunk and you have to remove most of the black plastic tab which hold the carpet cover. take all the tab off half way up the trunk start from the bottom. the tab is a bit tricky, there are to pieces, center and the outer. remove and pull out the center piece first and then pull out the outer. putting it back by putting the outer and the inner piece, if you try to pull them both out at the same time you will ruin the tab or break it. use finger nail or small screw driver to pull the center. remember, do not use plyer or needle nose to pull the tab out. fingure nail will do. remove carpet cover and you will see the tag light units, they are two set. remove the the bulb and replace.
good luck..
2helpful
Struts - Frt & Rear need replacing - 1995 Corolla - Special tools required?
you will need a good coil spring compressor(you can rent one at your local auto parts store),a good set of hand tools,(an air compressor would make it alot easier).Also you need to be extremely careful the springs are under a lot of pressure and can cause severe injury to your person if not removed properly.Lastly a good manuel that shows the break down and gives step by step instructions would be helpful.
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
