Computers & Internet Logo
Question about The Computers & Internet
Hello its ben here i have a 1997 mercedes 814D on 24 ml wheel nuts with washers do you know what the wheel torque would be
Thanks Ben :)
Posted by ben stanier on
Simon Atkinson
  • The Master
  • 3,367 Answers
Depending on the axle layout and wheel setup you have it will be 250Nm to 300Nm, (185 ft/lb to 220 ft/lb). The heavier 'twin wheel' axles will need the higher setting. The 814 is well known for wheel nut issues, especially the fronts so use wheel nut markers for your Daily checks and check every week with a torque wrench to avoid serious problems.
Posted on Feb 03, 2023
2answers
What is the wheel nut torque on a duel wheel sprinter rear nuts
As you can see from this Mercedes manual page, the specified torque for "wheel nuts" (not bolts, which you probably do NOT have) is 133 ft/lbs. Many reference sources quote a range of "126-140" foot-pounds for the dually-wheel Sprinter 3500.
https://www.manualslib.com/manual/805065/Mercedes-Benz-Sprinter.html?page=234
Regards,
Ellsworth
2answers
What part does the wheel bearing assembly sit attach too. big round steel connected to the strut
who fitted it, needs to be done by a proper mechanic or you could lose a wheel whilst driving. After it was fitted the retaining nut should have ben tightened fully home so that it could not have been tightened any more, then the nut should have ben undone/loosened slightly and torqued to the appropriate value. Then a split pin, if there is provision for one, should be fitted.
If you do not have proper tools take it to a mechanic to do the remedial work, it could be hazardous to yourself and family and also other road users.
Good Luck
Mercedes 814d vario will not start. How do I check fuel is getting to the engine?
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Windshield washer not workn
Hello my name is Ben. If you have plenty of fluid in the washer reservoir and all fuses are good your next step is to check for power at the windshield washer pump. Place the transmission in Park, set the parking brake and chock at least one rear wheel. Slightly loosen the front driver's side lug nuts and then jack up that side. Support the vehicle with a jack stand. Now remove the wheel and fender well liner to gain access to the washer pump. With a 12 volt test light check for voltage while someone operates the washer. If voltage is present, you probably have a bad washer pump. If no voltage is present then you will need to trace the wiring back to the problem. Hopefully you find a bad wire before the switch.
1helpful
How do I remove wiper arm
Hello my name is Ben. If you look closely at the end of the arm, you will notice there is a cap, use a tiny screwdriver to pry that cap up, then you will see a nut that needs to be loosened, then you wiggle the arm while pulling up. They are usually on pretty tight and I'm sure there is some sort of special tool (puller) to make it easier, but I just wiggle and pull. I hope this helps, Ben.
Torque for front lug nuts on 1997 GMC G3500 Savanna
140 foot pounds as per the GM specs.you can verify the spec online by going to alldata online
2answers
Door Bellows
ben it is very complex to replace
Top The Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
NADARK
NADARK
 Mike M
Mike M
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
