Question about Toshiba E-Studio 232 Copier
The issue with your Toshiba e-Studio 232 where it restarts after printing a few copies may be caused by several reasons. Here are some steps you can take to try and resolve the issue: Check the power supply: Make sure the printer is properly plugged in and that the power supply is stable. Fluctuations in power can cause the printer to restart. Check the toner: If the toner is low, the printer may automatically restart. Try replacing the toner cartridge and see if the issue persists. Check the paper tray: Make sure the paper tray is properly loaded with paper and that the paper is not jammed. If the printer detects a paper jam, it may restart. Check the fuser unit: The fuser unit may be overheating and causing the printer to restart. Make sure the fuser unit is properly installed and functioning correctly. Check for error messages: Check the display screen for any error messages. The error message may indicate the cause of the issue. If none of these steps resolve the issue, it may be necessary to contact a professional technician to diagnose and repair the printer.
Posted on Feb 24, 2023
