Hi everyone, hope someone can shine some light on a fault with my washing machine. After starting a wash cycle the drum will fill with water as normal, 5 mins later the machine will stop, the door unlocks and lights start flashing. Water is still in the drum. I thought this would be a blockage/pump issue. So I have checked the filter and wastage pipes. Couldn't find anything so deduced it was the pump itself. I have since replaced the pump and the same thing is still happening. Any thoughts? Thanks
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
