Televison & Video Logo
My real vr632hf will load and the tape goes around the barrel but none of the functions like play or rewind will not work
Posted by Dave Loftus on
Anthony
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 419 Answers
If your Realistic VR632HF cassette player is loading tapes but none of the functions like play or rewind are working, it may be a mechanical or electrical issue. Here are a few troubleshooting steps you can try: Check the belts: The drive belts that operate the cassette mechanism can become worn or stretched over time. Open the cassette player and check the belts for signs of wear or damage. If they are loose or damaged, replace them. Clean the heads: Over time, the tape heads can become dirty or magnetized, which can affect the sound quality or cause the cassette to not play at all. Use a cotton swab and some rubbing alcohol to gently clean the tape heads. Check the electrical connections: Make sure all of the connections inside the cassette player are clean and secure. Over time, dust and debris can accumulate in the connectors, causing poor performance or even complete failure. Check the motor: If the cassette player is not rewinding or fast-forwarding, it may be a problem with the motor. Check to see if the motor is running when you attempt to rewind or fast-forward a cassette. If it is not, it may need to be replaced. If these troubleshooting steps do not solve the issue, it may be a more complex problem that requires professional repair.
Posted on Feb 24, 2023
Old Teac A601R not working, when you place a tape in it just stops automatically. Is it worth trying to find out what's wrong or is it to old. When you place in a tape and press play it goes forward then...
The unit can be fixed in the right hands. The auto rewind function might be on but the reel rotation sensor is not seeing it move. Probably needs all new belts.
1helpful
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
2helpful
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
When play is punched in either direction it want move,not even in
yes, one nice overhaul will fix..(this can be done by you if you are daring...when u open take apart you will find a metal strip like band..I had used a bandaid for brakes the gauze side) you need new brakes (just like a car it is run down) on the reels in order for it slow & stop when it suppose to...or you can search and find a good old fashion repairman..(sorry I dont know of none)...for dragging, before playing all open reels fast fwd to one end then rewind it back to the beginning now hold the blank reel with that little bit catch tape try to tighten full side tape by going slightly going the other way not trying to stretch nor pop the tape.....now press play
1helpful
Basic Functions Don't Operate Near End of Tape
Defective optical end-of-tape sensor, or alignment of those related component....accordianman
VR632HF vcr
On my RCA remote I push on and hold the on/off button until the SAFE goes off. Maybe that will work with another remote. Hope this helps.
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Top Televison & Video Experts
Marvin
Marvin
