Computers & Internet Logo
Question about Power Computers & Internet
My Electrohome EAAC601 clock radio no power
I changed new batteries and tried new power outlets. No power
Posted by Stan Gray on
Gov B
    General:
    An expert that has over 50,000 points.
  • 121 Answers
If you have attempted to use new batteries and changed the power outlets with still no power, then it is likely that the clock radio itself is faulty and needs to be replaced. You should contact the store from which you purchased the clock radio and check if you are covered under warranty, as this would be the best option to get a replacement product.
Posted on Feb 14, 2023
1helpful
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
What will cause my radio,clock and power outlet not to work?
Let me ask a few questions: The items mentioned, radio, clock and power outlet...are these the only items not working? does the instrument panel light? Also , does the cigar lighter work? Lastly check fuse # 7(40A) in the battery junction box
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
After a power outage of approximately 45 minutes i have no display
Hello
There is a Lithium battery inside your clock to get a backup even the power is interrupted for a long time. This battery may last up to 3 years eventhough there is no power to the device. If this has gone weak, the backup fucntion will not be. so check this battery.
Just reset the device. It will make it work properly. To reset the clock after total memory loss; do the folloing.
[1] Connect the radio to your AC outlet and let the clock set itself.
[2] Depress the MONTH/DATE and TIME buttons together. The display will change
from 'Time'to 'Year'
While holding the MONTH/DATE and TIME buttons, press the SET + button
to set the display to the correct Year, then release the buttons
OK.
1helpful
Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Smart set clock dead ?
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Alarm
2helpful
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
1helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Open Questions:
Top Power Computers & Internet Experts
vince
NADARK
NADARK
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
