Heating & Cooling Logo
Question about Procom Heating & Cooling
The pilot in my Procom heater goes out almost as soon as I turn up the heat even just 1 notch. What is the problem/problems?
The unit is about 5 years old and has a new system about 2 years ago. Reggie
Posted by Reggie Macamaux on
john h
    Top Expert:
  • Procom Master
  • 28,881 Answers
Limited info generic answer ---failing --thermocouple ..regulator , gas valve ,-------thenmo out of alignment ---air in line
Posted on Feb 03, 2023
Pilot light on heater goes on and off when it is heating
If it is electronic ignition this is normal. If it is a standing pilot then you have a problem with the gas valve. With electronic ignition this will light the pilot on a call for heat.
1helpful
4answers
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
1helpful
Pilot won't ignite
For SBP12,
It will take some time for the gas to get to the unit, just turn it on and wait. It might take 5 to 10 minutes to fill the line with gas.
Just turns off?
From my memory, this is an unvented model. The ODS could be bad and turning off the unit or you could be experiencing a bad thermocouple. If there is any way to temporarly bypass the ODS, I would try this first. Do not run this unit unattended. If the unit stays on when the ODS is bypassed, you found your problem. If not, change out the thermocouple. It is a small diameter copper probe that goes from the gas valve up to the pilot light. Good Luck.
Top Procom Heating & Cooling Experts
Paul Carew
David Shaub
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
