Question about The Office Equipment & Supplies
What is the trick to get the the TI-8230 to "grab" the adding tape.
Posted by Iris Wilson on
Viktor Hoglin
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Hi!
To get the TI-8230 to "grab" the adding tape properly, you should follow these steps:
  1. First, make sure that you have a fresh roll of adding tape inserted correctly into the printer.
  2. Next, turn on the calculator and press the "feed" button to advance the tape through the printer mechanism.
  3. Once the tape is advanced, press the "clear" button to reset the calculator to 0.
  4. Begin entering your calculations, and the calculator will automatically print each entry onto the tape as you go.
  5. If the tape starts to slip or become loose, gently pull on the tape from the roll to tighten it, and then press the "feed" button to advance it through the printer mechanism again.
  6. If the tape still won't grab, try using a pencil eraser to clean the rubber roller that feeds the tape through the printer. Gently rub the eraser back and forth across the roller to remove any dust or debris that may be preventing the tape from feeding properly.
By following these steps, you should be able to get the TI-8230 to grab the adding tape properly.
Regards
Posted on Mar 18, 2023
My TI-5130 will not add and subtract
It probably uses adding machine logic. Try the following example.
3+
4-
5+
You should get 3, -1, and 4 on the screen, the running total. The tape should show the +3, -4, +5, and finally 4, the numbers that you entered and the total. Think of each entry as adding/subtracting integers on a number line rather than 3+4-5;)
Let me know if you have any questions.
Paul
1helpful
I have 2 battery watches that lose time when on only why?
try adding a little piece of foam tape to back of watch , the technical reason for this is that , the crystal that generates the time signal for the watch is being affected by the person wearing it body temperature , this is why the same watch might not be affected on another person , anyways the foam tape doesn't affect the person any but does add a tiny bit of insulation from there body heat , larger more expensive watches have thicker back cases for this reason as well , but the foam tape trick worked for me !!
Oct 29, 2015 • Watches
Adding 0
What does that mean adding? Displaying extra zeros? If that is the case Press [2nd][.] and limit the number of decimal you want.
You can put the calculator in FLOating mode: Press 2nd DRG and choose FLO.
You have to push my fridge door shut..
Make sure that it is level side ti side and even better to have it to be leaning back slightly. Another thing that will help is to have the door shelves full. This added weight will help the door shut on its own. The last trick is to apply some cooking oil to the door seal to make it shut easier.
My x-box360 controler keeps dis connecting, how do i stop it from happening?
is it wireless
if wired
u have to get duck tape and tape the usb port
and the wire that connects and tape that too
ad ur good to go if wireless
get new batteries
or keep ur xbox on for 1 hour it should do the trick im out peacee
2helpful
Have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
2answers
Problem Sony VAIO PCV-W510G
maybe this can help you,please try to replace the fan or you can also clean it.. http://www.docs.sony.com/release/PCVW510G.pdf
3helpful
3answers
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
6answers
My iphone's ipod stopped playing songs properly and i cant get connected to wifi even after i restored it it still has the same problem
Sounds like a firmware issue to me, so I would think updating the firmware should help. If not, virginizing it may, but since I haven't encountered this problem, I really can't say for sure.
Good Luck.
Top The Office Equipment & Supplies Experts
vince
old marine
old marine
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
