I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at reliable-store
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
Pull up the top of the pen (with the clip). Remove the refill cartridge and examine it. If it is not damaged put it back in and fasten it in place by twisting. The cartridge comes with a colored plastic top. The cartridge must be inserted with the plastic on.That top must not be removed.
Exactly the same thing happened to me (0.5mm GG 1000). I carefully unscrewed the barrel (just above the lead indicator), then unscrewed the interior cartridge (it's a sort of beige colour) just above the tip of the pen. There was a little ring that I guess expand to feed the lead. There was a tiny piece of lead stuck in this ring - I moved it out with the tip of a needle and the pencil worked again.
Basically - might be worth unscrewing before you buy a new one.
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
was it a ball-point or ink pen tip???
if it is ball-pint. then all you have to do is get a refill cartridge from any of the office supply store or specialty shop.
if it is a fountain pen tip, then you have to send it back to cross for repair.
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first
(untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*)
Grasp your pen in both hands with the tip facing to the left
left hand should be grasped covering the tip and ONLY the section that has the recessed barrel with the raised button ridge.
Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands)
CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
The stylus pen works by pressure on the tip. Since the tc1100 uses an active digitizer, as soon as you come within range of the screen, the mouse should move (this is called pen-hover), however, if the tip is stuck upwards it will write or click instead just as if you were touching the screen.
Try carefully pulling out the tip using a needle nose pliers or your fingernails if they're strong, and then reinsert the tip gently. This should un-stick it. If this doesnt work, there may be an internal problem with the stylus.
