Sewing Machines Logo
Question about PfaFF Sewing Machines
Pfaff Hobbylock 788 serger feed dogs run backwards
They move the fabric out instead of in.
Posted by james lantz on
1helpful
The feed dog on my Pfaff Hobbylock 784 broke in half. Are there any replacements?
Hello, Mary -
I am having no luck in finding a replacement feed dog for your specific model of Pfaff sewing machine. I suspect a replacement feed dog is available your model and other Pfaff models.
If you can locate an authorized Pfaff sewing machine repair business in your area, someone there can probably tell you what the right part number is for the feed dog and may be able to sell you one.
This is the link to the Pfaff Machine Support web page:
http://www.pfaff.com/Support-and-Updates/Support
Best wishes.
1helpful
Hello, I have a very old but wonderful Pfaff 260 automatic and the feed seems to be going backwards but is not pulling the fabric at all?
First, verify that the stitch length is set high enough that the feed dogs should be pulling the fabric to create a stitch.
If you have not recently oiled the machine, the feed dog mechanism may be stuck due to old oil that has solidified. Pick up some liquid Tri-Flow Synthetic Lube. While gently rocking the handwheel, apply a couple drops everywhere that metal rubs against metal. Do NOT oil rubber, leather, or synthetic parts!!! Don't forget to hit the spots under the sewing surface, ie the feed dogs, bobbin area, etc. Also, move the levers and selectors and hit those with a couple drops of oil. If things are still a bit sluggish, you can apply hot air from a handheld hairdryer at the interior of the machine. The heat will help loosen things.
P.S.--I picked up a frozen Pfaff 260 at the thrift store for $25. Used the above method to get things loose and now it sews beautifully!!!
1helpful
How do i tighten the needle holder on a pfaff 788 hobbylock serger
I have the same problem, thee needle holder shaft swirls from left to right, is very loose. Maybe there is a screw missing, but which one? Please look at the pictures.
Hobbylock 799 threading
take the serger back and get another one,
from one seamstress to another
2answers
I need a manual for a Pfaff Hobbylock Serger 4762, where can I find one
I can't find a manual for this model, however there is a general hobbylock book http://sewingonline.co.uk/library/know-your-pfaff-hobbylock.html which would certainly be a good start.
You may find best source is to contact Pfaff locally and source it from them direct.
You could also try www.diplodocs.com, I can't see this manual but if you go through similar model numbers manuals you may see one very similar. Overlockers/Sergers are very similar in many ways so once you've mastered one, the next one is pretty straight forward. Four tension knobs, 2 needles and 2 loopers is the norm - to get a three thread stitch you just don't thread one of the needles. Tension adjustments alter the stitch formation, and you should have a stitch length knob on the right side of the machine along with a flywheel and if it has it, differential feed (which controls the feed dogs so you can stretch, or compress the fabric as it goes under the foot).
There are some good general how to use a serger books in the marketplace too which should help. Threading up, many machines have a diagram inside the front flap, colour coded dots on the knobs, eyelets and loopers. And oiling points are often marked on this diagram too. But basically oil the two loopers where they slide/move on another metal part. Some good info here too http://sewing.about.com/od/sergersoverlock/Sergers_Overlock_Sewing_Machines.htm
Hope this assists you a little.
4helpful
3answers
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Pfaff Hobbylock 788 Serger won't work
Does it still make noise? Maybe it needs a new belt or just some oil?
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
