Recently relocated a LG Fridge Model GS-L668PNL Dual Door fridge to new premises. Both the Fridge and Freezer doors had to come off to fit through narrow doorway. Both doors were refitted back the same way and all wiring was reconnected incl ground lead and water lines at bottom of fridge. Fridge left to sit for quite a few hours for compressor oil to return and gasses to settle. Turned on fridge later that night to find fridge working (Fridge and Freezer) cooling nice and cold and lights working inside of fridge but the entire front display panel was off. Ice Maker seemed to be making ice and only crushed ice working only as Cubed and water cannot be selected when placing a glass cup underneath. Retraced my steps incl checking all wiring again and everything is connected as it should. No wires look pinched either around L/H Upper Door Hinge. Disconnected the two main plugs on L/H Upper Door Hinge and found ice maker didn't work but fridge lights still on and cooling fine. Reconnected both of those plugs back again but display panel still doesn't work but ice maker does. Have ordered another Control Panel (Display) in the hope this fixes it. Any suggestions please on what else it could be thank you.
It is possible that the issue is with the control panel (display) itself, as you have ordered a replacement. However, before installing the new control panel, you should check the wiring connections and make sure they are secure and not damaged. You should also check the electrical supply to the fridge to ensure that it is functioning properly. If the issue persists after installing the new control panel, you may want to consider calling a professional to diagnose the issue.
