Televison & Video Logo
Aim 60 Inch Digital UHD. There is no sound from my dstv HDMI connection only, picture is fine, decoder tested by dstv fine, other HDMI inputs work fine, I know the HDMI cables are fine. please assist.
Aled-60uhd tv
Posted by Gabriel Murugan on
Anthony
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 419 Answers
If you're not getting any sound from your DSTV decoder when connected to your Aim 60 Inch Digital UHD TV via HDMI, there are a few things you can try:
  1. Check your TV settings: Make sure that your TV's audio settings are set correctly. Check that the volume is turned up and that the TV speakers are not muted or turned off. Also, make sure that the TV is set to receive audio through the HDMI input.
  2. Check your DSTV settings: Make sure that your DSTV decoder is set to output audio through the HDMI connection. You can usually check this in the settings menu on the decoder.
  3. Try a different HDMI input: If you have other HDMI inputs on your TV, try connecting the DSTV decoder to a different one to see if the problem persists. This will help to narrow down whether the issue is with the HDMI input on your TV or with the DSTV decoder.
  4. Try a different HDMI cable: Even if you think your HDMI cable is fine, it's possible that there is an issue with it that is causing the sound problem. Try a different HDMI cable to see if that resolves the issue.
If none of these steps solve the issue, it's possible that there is a problem with the HDMI input on your TV. In that case, you may need to contact Aim customer support for further assistance or consider bringing the TV to a repair shop.
Posted on Feb 24, 2023
How to connect my Panasonic TH-42PW6 television with DStv decoder please?
Buy a new television! This old dinosaur appears to be made to connect to a laptop only! No HDMI ports and no Composite Video connections that I can see. You would need an HDMI to Serial Port cable
https://www.manualslib.com/manual/648891/Panasonic-Th-42pw6.html#manual
https://www.google.com/search?q=Panasonic+tv+th-42pw6+connect+to+DStv
My new 50-inch Samsung UHD 6500 has no sound when I watch cable TV. When I test the sound on the TV itself, it works fine.
if you have cable box: replace with a known good audio (wires) or hdmi cable from box to tv.
2answers
How do I connect my receiver so that the sound comes from my speakers????
Please read the manual. You should connect speakers to the speaker output of the receiver, or amplifier. You connect the TV with a receiver through a HDMI cable. Depending what would be the source from that you take the output and the place the signal is going to there you should use the input. Don't connect anything without 100% certainty it is correct. You could damage the whole equipment when connected the wrong way around.
Can I get Chromecast to play thru my surround sound?
If your receiver has an HDMI input that you are connected to from an HDMI output of your TV; then yes you can listen to it in surround sound.
The HDMI input that you are using on your receiver must be designated as a TV input if it has the capability of being "assignable" in your receiver setup options; or otherwise just connected via HDMI on the rear or front panel of the chassis on TV inputs section.
Once the proper connections are confirmed, select your receiver input to TV. The TV output mode must be set to HDMI; or you will not get any sound or picture if that is the only connection. You'll have to refer to the receiver manual on how to do this if the output mode does not select automatically as I do not know what gear you are using.
If you have your speaker setup in a 5.0 or 5.1 setup; depending on the decoding capabilities of your receiver; you should be able to get audio through each channel in a variety of ways. Refer to your receiver manual for the decoding format compatibility. The decoding may also be performed by your TV as well.
I bought a hisense lcd the problem is there is no
Unless you are using an HDMI cable, maybe you have the sound cable attached to the wrong port, or maybe you need to go through the menu options and see if the speakers are turned on.
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
3helpful
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Open Questions:
Top Televison & Video Experts
Marvin
Marvin
