Televison & Video Logo
Car Headrest DVD player with pictures but no sound. Its a stand alone unit but no sound comes out when playing, checked the volume all gone but no sond
It's a 10.1" Slot-in Car Headrest Monitor Portable DVD Player TV Screen HDMI USB AV IN
Pawel Nietyksza
    Master:
  • 318 Answers
It's likely that the problem is with the audio output of the headrest DVD player. Check the connections and cables, make sure that the audio cable is securely plugged in both the player and the car's audio system. If the cables and connections are fine, try resetting the player and checking the audio settings to make sure that the sound is not turned off or set to low. If these steps don't solve the problem, it might be a hardware issue, and the player may need to be repaired or replaced.
Posted on Feb 01, 2023
I hook my farenheit dvd player up every thing comes on but no sounds comes out of it what could i have wrong
It looks like a stand alone dvd player from the picture and there is no sound power so to speak for those units just a left and right audio signal ( Red and White ) Yellow is for video of course. Make sure you have the red and white audio OUT going into the INPUT of your power ( your main radio ) and as long as your radio is working correctly you should have sound. Some of those stand alone units come with a 3.5 mm or 1/8 jack and you have to make sure which is audio and which is video and get them to the right inputs of your radio. if that doesn't work check your radio am/fm or cd player and if sound works with them it is probably not getting the audio signal correctly. Good Luck !
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
I bought my first RTD215 2 years ago but the dvd player got stuckand wont open nor play... I bought another unit same model and after 8 months the same thing happened.. the dvd player got stuck again but...
If you really like the unit (disregarding the DVD player issues), maybe you could buy a GOOD stand-alone DVD or BluRay player and be ready for an upgrade in the electronics when the bug bites.
2answers
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
1helpful
Dvd player
I have the exact same problem. No video, but the sound plays. Any help??
1helpful
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
1helpful
2answers
SAME old! JVC files mod, have converted with prism to avi in the past, with success. Now DVD player says (once) cannot read (next time) not compatible. using DVD-R
Are you talking about a stand alone dvd players?
If you are talking about a stand alone dvd player, that is correct they do not player .avi extension file. I know some portable dvd player can play avi extension files.
all avi extension files needs the right audio and video codec to be player. All stand alone dvd players does not and can not detect codec for you.
On the issues of dvd-r brands, Some stand alone dvd players can only play dvd+r type dvds. ck your brand of dvd disc and players, make sure they are complatible with each other.
1helpful
2answers
Dvd player won't read disc
I believe Vizualogic has serious quality problems. I had RT20 installed and it was defective to start with. The headphones did not work on one unit and the other unit made a loud sound when it was turned on. I had the units replaced. The new units had a new problem - Disc Error. The players were not able to read the discs. The installer tried another unit and it also had the same disc error problem. Interestingly, the word disc was spelled as DSIC - can you believe the quality control on Vizualogic prodict?
The installer then found that a wire had come loose in one of the units. He applied some tape to hold the wire in place. The unit seemed to transmit sound again. Well, a broken connection, disc error in multiple units and incorrect spelling was enough to turn me off. I am now trying to get some other brand installed.
Strong humming sound coming from the over head speakers
are you running a stand alone dvd player or is it built in?check all plugs for sources coming ineg.dvd,vcr,xbox etc,if one is not in all the way,this will cause a hum.
Video output not working
it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
Top Televison & Video Experts
Marvin
Marvin
