Computers & Internet Logo
Question about Power Computers & Internet
I have a tajima TMEX C901 single head machine and the X motor get power but not moving what can the problem be.
The y axis are moving but X axis are giving vibration sound but not moving when you press the cursor on control panel
focalsteam n
  • 3 Answers
Good morning. How do I fix error cose 316 on a single head TEJT2-C1501 Tajima embroidery machine please
You could look online, or get in touch with any sewing store nearby, that handles your machine. The owners of it Really want to make you happy, and will help, any way they can.
How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
1helpful
Tajima Tmex C-1201 won't light up ?
I went google and typed in --workshop manual for tajima tmex c-1201 sewing machine -- and found many pages with pdf downloads for repair manuals and workshop manuals
do that and find the right site for you and down load the workshop manual and that may be a way of fixing your machine
Where is the degree wheel?
On a single head it is usually located on the back right through a small window. On a multi-head it is on the left or right end of the machine. It would help if you posted the model--I could be more specific.
1helpful
Tajima c1501 axes code
Can you be more specific? Are you getting an axis code on the display? If so, what number is it?
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
I have a Tajima TEHX C1501 and it is not moving left and right. The controller only moves it back and forward. Sometimes, it works when I turn it off and on, but most the time it doesn't move right and...
I have had a couple of Tajima units with what sounds like the same problem. I found the motor which drives the X axis had bad solder joints where the windings join the circuit board which the cable attaches to the motor. I resoldered the connections and they worked fine. If you don't have the soldering skills, or know someone who does, you may just need to replace the motor which is fairly expensive. It will probably take about 1 1/2 hours to take the motor assembly in and out, and about another hour to repair the solder joints.
6helpful
What is a 211 error code on a tajima 2 head emb machine
A 211 is generally caused by the degree wheel not resting in the "red" zone. This zone indicates the machine is in a ready state to start or shift. Look at the degree wheel and manually move it to the zone (around 100-110 degrees). If this doesn't work it will need repaired. It usually takes 1-3 hours depending on what is involved.
Open Questions:
Top Power Computers & Internet Experts
vince
NADARK
NADARK
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
