Yes, the water inlet valve is leaking and letting water in past a faulty seal. The valve just needs replacing with a new one. They are not serviceable.
The hose could be clogged or an issue with the valve assembly.Or something being stuck in the inlet water valve. Check to see if there is any problems coming from where the water enters into the tub for your dishwasher mostly on the left side wall of the tub on your dishwasher.
Some companies share generic codes like 'Lw', for low water level or 'DL' for Door Lock. This might help, there are other sites when Googling 'make model error codes'.
Error/Fault Codes for AEG Dishwashers with an LED Display Fault Code ,10 Symptom: Dishwasher not filling with water. Go to: Why is My Dishwasher Not Filling ...
Owner's manual should have a troubleshooting section.
Canal? you may have a serious leak in fill piping or control valves. or drain system.
No owner's manual? Try MFG website or http://www.manualsonline.com/
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Check that water and power are switched on properly, and that inlet hose is clear. Check manual first, if no answer or this doesn't fix, then contact manufacturer or service agent.
