Question about The Audio Players & Recorders
Midas Venice series 320 repair - blown channels
Hi, have a Midas Venice 320 with some blown channels - possibly 48v misuse. Are the parts available? Op-amps? Fixable? I can pull it apart just not the rest at this stage.
Posted by Paul Kneipp on
Anthony
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 419 Answers
If your Midas Venice 320 has blown channels, it is likely that the op-amps and possibly other components in the signal path have been damaged. The parts required for repair will depend on the extent of the damage and which specific components have been affected.
In general, op-amps and other components for audio equipment repair can be sourced from electronics suppliers such as Digi-Key, Mouser, or Newark. However, if you're not experienced with electronics repair, it is recommended to seek the assistance of a qualified technician who can diagnose and repair the issue.
In terms of repairability, the Midas Venice series is generally regarded as a well-built and serviceable mixing console. However, the cost and difficulty of repair will depend on the extent of the damage and the availability of replacement parts.
Posted on Feb 24, 2023
Allen & Heath XONE:42 Professional Four Channel DJ Mixer. How to repair a blown left channel blown?
If one of the channels on your Allen & Heath XONE:42 mixer is not functioning properly, it is likely due to a problem with the channel's internal components or electronics. To repair a blown left channel, you will need to disassemble the mixer and locate the source of the problem.
Here are the general steps you can follow to troubleshoot and repair a blown channel on your Allen & Heath XONE:42 mixer:
Disconnect the mixer from any power sources and remove any cables or accessories that are connected to it.
Carefully disassemble the mixer, following the instructions in the user manual or a service manual if available.
Once you have access to the internal components of the mixer, carefully inspect the left channel for any visible damage or problems.
If you find any damaged or faulty components, you will need to replace them. You may be able to find replacement parts online or through a specialist DJ equipment retailer.
If you are not comfortable with disassembling and repairing the mixer yourself, you may want to consider taking it to a professional repair service. A technician will be able to diagnose the problem and repair the mixer for you.
Keep in mind that repairing electronic equipment can be complex and requires specialized knowledge and tools. If you are not familiar with electronics repair, it is recommended to seek the assistance of a professional.
2answers
Clip led
That particular channel is blown. These are not the easiest units to repair. Given that this is a commercial amp, I would recommend that this unit be brought to an authorized Crown service center for repair. Expect parts cost in the $50 range plus the labor charge.
Dan
I need the availability of replacement "hang-up" knob for the executive series 100 mic
Hi Rande,
Have you tried the manufacturers website, usually the carry spare parts for your set and these parts are usually compatible with a number of other sets in the series.
Garmin is a reliable company that provides great backup and after sales service, give them a try.
I wish you well, and I hope I have assisted you.
Cheers,
Peter
Is burning my component, I need trasistor M50D060 s thank you
You have bigger problems than just the IGBT. I replace that part with part number:
APT28GA60BD15
About $6.50 from Digikey.com
You will probably find one or both of the gate speedup diodes blown PN DL4148 surface mounted an one or more of the driver transistors 2SSA1020-Y and 2SC2655-Y blown and usually the IR2153 switching regulator chip. If you haven't blown the 10 ohm ceramic pre-charge resistors you are lucky. Put a 150 watt lamp in series with the power cord to save fuses and parts till it is repaired. If you don't have schematic get back to us.
4helpful
3answers
Hi, my M-audio Project mix stop to send 48V phantom power, Do you know if had a fuse protector inside? Tks Wallace
A common problem is a person will plug in an unbalanced plug into an input. this often grounds out the 48 volts. Use ONLY balanced lines like XLR and TRS connections. There is NOT likely a fuse inside as the 48 volts have fairly high impedance driving the mic leads... around 6K ohms. Verify that the 48 volt control setting has not been turned off.
Hi I got PMP3000 and all of a sudden in the program smoke came out of the unit and I unplugged the Mixer...I have given it to repair and they saying the Main power SMPS has blown out..they charging too...
Sorry... you likely have one of the power amp channels bad as well. One does NOT replace the power supply, instead repair it. You need a competent repair shop. I can tell you what parts are blown on the supply. They cost about $30 max for parts to repair the power supply. There usually is about $15 of parts blown on the amp that caused the problem and significant labor to repair the amp portion. If the smoke was dark or heavy, it was likely from the 0.03 ohm metering resistor on the bottom of the amp circuit board that caused the original problem. If one replaces the power supply and turns power on they will find one side of the amp doesn't work and MAY blow the power supply again immediately. I have repaired several of these units and have walked others through the repair sequence as well. You can contact me directly by email for more info if you need it. Unless you can find a competent repair shop that replaces components, including work on surface mounted boards, the cost of the module parts AND availability will preclude repair. The amp module is another $155 after the power supply is repaired if a channel is bad and one chooses to replace rather than repair.
I have a midas venice 320 mixer, there is no output on the four auxlilary sends, but i have an output on other outputs and headphones.
You must have aux sends on each individual channel and each AUX MASTER turned up for output and each of those outputs must be going to separate amps.
1helpful
2answers
Hi, I have 1995 toyota camry that has automatic power doors & locks. Suddenly, this evening the complete power doors & locks stopped working. So this means i can't unlock all the doors...
You have a blown fuse that controlls these functions. Any knowegable person (auto wise) should be able to help you.....freind relative co worker . Its a simple fix that usually doest require a visit to a shop. Good luck!
2helpful
Have reverse-connected power to Nuvi 260W. Has blown a component which I suspect is a protection diode but cannot identify to replace. Would like to get hands on a circuit diagram please.
These diagrams are not available to the consumer and are proprietary to the manufacturer given that the product is still covered under warranty repair.
Remove the part and using an ohmmeter, determine if its shorted. If it is a diode, you don't have to use a SMT diode, a leaded part will do just fine, like a 1N4001-1N4007 or smaller series diode. It may be difficult to solder but is is possible.
- Jim
SHARCNET-USA
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
