Water Heaters Logo
John Emmerling Posted on Jan 29, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Rheem RHIN-CHL25P The error code 160 keeps coming on. Do you know what the problem is? This is a new unit.
Steve Pack
Level 3:
  • Rheem Master 7,128 Answers
  • Posted on Jan 29, 2023
Steve Pack
Rheem Master
Level 3:
Answers
7128
Questions
Helped
2276073
Points
27978
This from Rheem error codes
Error Code 60
FAULT = Hot Water Temperature Abnormality
  1. Press the Power button to clear the Error Code. If Error happens again:
  2. Ensure water heater inlet and outlets are open and water is supplied to the water heater.
  3. If Error happens again:
  4. Ensure water heater inlet and outlets are open and water is supplied to the water heater.
  5. Check the pump operation.
  6. If it doesn't work, ensure wiring connections to pump.
  7. If even supply power to pump and doesn't run it, replace the pump.
  8. If Error happens again:
  9. Verify recirculation loop length is within specification. Air purge is not enough.
  10. Too much restriction on recirculation loop.
  11. Return loops are clogged.
  12. Check the recirculation loop condition.
  • Steve Pack
    Steve Pack Jan 29, 2023
    if unit is new call for service under warranty
Rtg74pvn2 rheem tankless water heater gas problem
1) You want the truth: Forget tankless.
There are many tankless water heaters with insoluble problems.
And endless problems.
Rheem knows it.
2) Do you really expect your home computer to work flawless after replacing motherboard?
Get your money back from Rheem, or get a full replacement.
3) OR fix water heater yourself today: Install tank-type gas water heater for $350 from local box store.
FYI: Do not buy Rheem, Richmond, Ruud, GE as these units from Rheem have problems that require service technicians.
Instead buy Whirlpool, American, State, Craftmaster, Reliance, Kenmore, as these units from AO Smith have fewer problems and can be repaired by homeowner using simple part replacement.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
4) Copy following link for troubleshoot resources, and possible manual for Rheem, Richmond, Paloma water heaters:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
2answers
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
5helpful
4answers
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
1helpful
2answers
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
2helpful
3answers
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
www.howtolou.com/clean-a-burner -Lou
2answers
I keep getting a C2 11 error code. Unit lights and immediatly goes out showing that error. At other times it operates fine. The problem seems to be occurring more frequently. It has been in service...
that error code means not enough gas.
however, there might be something going on with your venting. it could be sucking exhaust air back into the unit. this will cause the same error code.
if your problem is intermittent, then I would suspect the venting to be the issue.
1helpful
2answers
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
7helpful
5answers
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
123helpful
11answers
Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
