Computers & Internet Logo
Question about HP Computers & Internet
Internet Adapter issue, it keeps losing network.
HP Windows 10 keep losing internet connection. The troubleshooter says internet adapter problem it then fixes fixes connection. It lasts for a while then I have to run troubleshooter again and go through the same process. Does anyone know how to fix this?
Posted by DJAC (DJAC) on
ADMIN Andrew
    Top Expert:
  • HP Master
  • 57,075 Answers
Question edited to tidy up the written English.
I have this issue on a wired Desktop computer that uses a plug in gadget that takes the internet from my basement rec room where the television and router is and sends it via the house wiring to the 3rd floor where the computer is.
Put the App Speedtest on your smartphone and run it when the computer network drops out. My 50mbps internet drops to 11.6 or worse. Not sure why Bell Canada has this issue, but I notice my Internet is now labelled 'Century Link'.
Posted on Jan 29, 2023
2answers
Why does it keep loosing Wi-Fi connection?
I
is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - The symptoms are a wireless connection that literally will drop out .... the 5th router is wireless CPE AP, wifi signal keep droppings all the time I ...
WiFi problems! Keep losing connection! - Tom's Hardware
www.tomshardware.com/.../wifi-problems-losing-...
Tom's Hardware Guide
Nov 15, 2015 - 9 posts - ‎5 authors
Ok so for some reason ever since we got a new modem and router my HP laptop willhave a full connection and all of a sudden ill lose it and my wifi says "No Networks available" and a red X appears by my bars at the bottom. ... I dont know if maybe my network adapter is going bad or ...
A fix for my Windows 8
Problem with hp pavilion g6 wireless
I will be happy to help with your wireless issue. However, that is difficult as you didn't leave a lot of information to work with. I have included a few links below depending on your operating system.
HP Notebook PCs Troubleshoot Lost Internet Connection on Wireless Network...
HP and Compaq Desktop PCs Troubleshooting Your Wireless Network Windows...
HP PCs Troubleshooting your wireless network and Internet connection...
HP PCs Troubleshooting Wireless Network and Internet Windows 8
Here are a few additional wireless troubleshooting steps that you can try:
Power cycle the network:
1. Shut down your notebook.
2. Unplug the power to your router.
3. Unplug the power to your modem.
4. Wait at least 45 seconds.
5. Plug in the modem, and wait for it to come back online.
6. Plug in the router, and wait for it to come back online.
7. Turn on your notebook, and test your connection.
Reset the TCP/IP settings:
1. Go to your start screen/menu and type CMD.
2. Right click on the command prompt icon and chose Run as administrator.
3. In the window that opens type "netsh int ip reset resetlog.txt" without quotes, and press enter.
4. Restart your PC and test.
Reset the winsock catalogue:
3. In the window that opens type "netsh winsock reset" without quotes, and press enter.
Change power management option for your wireless adapter:
1. Open Device Manager.
2. Expand the Network adapters.
3. Right click on the Ethernet/Wireless Adapter and click Properties.
4. Click the Power Management tab.
5. Remove the check mark beside Allow the computer to turn off this device to save power.
6. Click OK.
7. Test.
Forget the Network and reconnect (Windows 8):
1. Press Windows Key + C
2. Click Settings.
3. Click Change PC settings.
4. Click Network on the left.
5. Click Manage known networks.
6. Click the network name.
7. Click Forget.
8: Reconnect
Thank you,
BHK6
I work on behalf of HP
My dell 8300 keeps losing connection with the internet, the connection is good the ethernet light is red
1. Disable your windows firewall immediately or allow the firewall to permit the ping.
2. 127.0.0.1 is loopback address to ensure your network card is working fine.
3. Change the network cable with serviceable one.
4. Un-install the driver and reinstall with new one from OEM site
1helpful
My WBR-1310 keeps losing connection every 10 mins or so. Is there a fix I can download to my router? (like an update or something)
I got your issue, since your facing the frequent disconnection in the internet connection,
ftp://ftp.dlink.com/Gateway/wbr1310/Firmware/wbr1310_firmware_104.bin.
Please download the firmware using this link and log into the router setup page of DLink with 192.168.0.1 and update the firmware
I'm sure this will help you to fix the issue.
Thanks & Regards,
Prema
Windows cannot connect to the wireless network
I would remove old cache wireless network connections. Example is when you once connect to a free wireless access at Library or Coffee Shop. Windows save all of these profiles and this will cause problems connecting. Then use Microsoft Wireless Troubleshooting resource:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Good luck
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Belkin Wireless G+ nic can't keep internet connection
check if ur able to gonline with the cable connection. checked if the wireless key entered is correct
try to update the software
go to start-computer-right click-properties-devicemanager-network adapter- rightclick on the broadcom -update driver from the net with the cable connection and this will probably resolve the issue
2answers
14helpful
6answers
I installed netgear adapter WG111v3 and I keep losing internet connection
I had the same problem and when checking the properties of the adapter under device Manager.
I found the under the Power Management Tab the option to
"Allow the computer to turn off this device to save power" was turned on.
Remove the check mark from this option and click OK.
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
