Televison & Video Logo
Question about Sanyo Televison & Video
My Sanyo tv dp42841 screen is upside down and mirrored I tried resetting and not fixed how do I get it back to normal with universal remote
Posted by Romero Trent on
Aron
    Top Expert:
  • Sanyo Master
  • 2,485 Answers
You will need to click on the menu button on your TVs remote and then select the factory menu and next click on the factory settings to have the screen be not upside down anymore.
Posted on Jan 29, 2023
Sharp lc-55n7000u half screen upside down
There should be a setting on your TV that is called Picture Flip. See if you can access it with your Sharp remote (not a Universal remote)
Press MENU
Scroll left or right to SETUP
Scroll up or down to PICTURE FLIP
Scroll up or down to STANDARD
Press ENTER
Press MENU
That should turn your picture normal. Let us know if it worked.
I have a Sanyo Model DP42841 and I want to know how to stop the texting that comes when people are speaking?
If your source is the TV (RF input), then the Caption button on the original remote for the DP42841 will let you cycle through the available closed caption options. If you have a universal remote, you'll need to find a code that lets a Caption (or CC) button work with this TV. This is shown on page 8 of manual. ManualsLib has the manual here: https://www.manualslib.com/manual/148706/Sanyo-Dp42841.html .
If your source is any set-top box, you need to disable the captions on that source. This can depend on the system setup. I know that on one satellite dish receiver, the captions for a second TV on the system had to be enabled from the primary TV. (Then the captions showed on both TVs.) On a IPTV set-top box that I use, to disable the closed captions, I need to enter the Settings menu using a pass code from the provider. Then the setting is under Audio.
I hope this helps.
My tv is on a menu screen but will not go back to normal screen
there should be a menu button on the set. or you can try unplugging the set for a minute and plug it back in this may reset it. if none of this works get a universal remote
Sony tv remote codes
Check these codes.
0049 0097 0110 0004 0268 0012 0108 0180
6helpful
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
39helpful
13answers
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
1helpful
5answers
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
